Whats that in there
Broken bits!Whats that in there
thats a lot of bits was there any thing left of the piston ?Broken bits!
Whats that in there
Thanks for that- well I don't even know for sure if it does run this is the saw advert:
View attachment 443592View attachment 443593View attachment 443594View attachment 443595View attachment 443596
So hopefully when it arrives tomorrow/ Tuesday it won't be seized and I can start checking it out properly.
The primer bulb appears split in the pics so I have a new genuine one ordered too. (£5 as its the plastic bulb only) I have a new spark plug coming too and will try and get it running first with that then take stock of what else is missing but not much.
Today I received Joe’s surplus saw. Started first time. He’s done a good refurbishment job. Can not try cutting in anger tonight rain has only just stopped and don’t want to **** neighbours off, as it’s getting a bit late. I got a new blade for it yesterday which I can’t wait to try.
It will be a TS500i then as that is the only difference between a 480 and 500 - the diameter of cutting disc fitted. Similar to a TS410 and TS420 whereby the only difference is the guard/ arm and the parts are all interchangeable.
Phew.
what casing broken ?I sold 2 of my TS400's tonight so they are away to do some work with their new owners.
So I no longer own a fleet of consawsPhew.
The TS350 was painted so I'll start rebuilding that next weekend.
The TS480i developed head bolt issues so it's taken apart at the moment.
The TS420 14 inch one is really too good to split apart so I'll keep it as is.
The 14 inch cuts deeper but it is noticeably heavier and not as nimble. So having the TS480i 12 inch one as second saw makes sense to me.
So that's what I have now really 3x of them. There are a couple of parts saws sitting that aren't really worth fixing but maybe next winter I'll return to them. (TS400 and TS410 both with broken casings)
pmed youThe TS410 has the mounts broken off the engine casing. For it I will attempt Mag TIG Repair. (£100 or so for the rods)
The TS400 has severe damage to the crankcase and handle as it fell from scaffold or similar! So it's probably a parts mule unfortunately unless I get a cheap core and swap the recoil and other bits onto another one.
