Thanks, will look into it.there is apparently a way to get paid with out being MCS.
it is under octopus and it claims all that is needed is a G98 or G99 submitted to the DNO, but this is only changed in the last 6 months or so
I was going to post the same.there is apparently a way to get paid with out being MCS.
if you pay an electrition to check and inspect the install therefore signing off the work thats been done then that should be good enoughNo disrespect to you, but from what I've seen, to install better than some accredited companies is not difficult. However, you won't be allowed to be paid for your export, which is absolutely wrong, electricity is electricity.
current Octopus faq - the last paragraph being the pertinent one..I was going to post the same.
And yet, this page from an independant training provider says:
An MCS accredited electrician. And one that is willing do do it. Not easyif you pay an electrition to check and inspect the install therefore signing off the work thats been done then that should be good enough
its good enough to import from the system therefore should be good enough to export to the system
i agree but i also find it highly restrictive as wellwell I would expect the MCS installer provides a certificate of sorts.
Panels would come with some worthless bit of paper, and the inverter would need the G89 or whatever it is now.Maybe a test cert from a sparky, 18th ed quallified.?
What nonsense - if it was all well defined we wouldn't be discussing it. So do you have to have an MCs certificated scheme to get paid export? Two days ago I thought the answer was yes...There is so much confusion here. And there doesn't need to be. MCS, FiT, SEG, DNO's Gxx certification etc are all well defined and have rules as to what is an isn't allowed.
As a general rule, if you require a certain standard/setup/certificate in order for a company to pay you for something, if you deviate from those rules, the company will be quite happy to legitimately stop paying you and continue to take your generation.
Conjecture about what is and isn't allowed on a forum isn't needed or helpful.
I wouldn’t go as far as far as calling what Gareth said nonsense but I agree with you though, it’s not completely clear cut. It is strange that octopus seem to have a different stance.What nonsense - if it was all well defined we wouldn't be discussing it. So do you have to have an MCs certificated scheme to get paid export? Two days ago I thought the answer was yes...
Sorry, my post wasn't really in response to your queries but other conjecture based posts. There is apparently ambiguity as to whether octopus will sign you up to SEG without an MCS cert. Which is why I suggested emailing them for clarification.What nonsense - if it was all well defined we wouldn't be discussing it. So do you have to have an MCs certificated scheme to get paid export? Two days ago I thought the answer was yes...
My (not) suggestion was nothing to do with FIT. As you rightly suggest, that could and potentially would be detected easilyApology accepted but not needed. This suggestion takes us back a few pages where we did discuss suppliers running exception scripts to identify potential fraud - which if the previously accredited system is in receipt of FITs is what you're describing above is. The FIT payment scales were essentially a kick start to renewables by the last Labour g.ment, and they made a massive boob by setting the rates too high, something that has been well documented.
I have dealt extensively with hydro schemes, and the major red flag would be water pumped up a hill, using say 15p electricity, getting FIT payments at 20p at the turbine, so OFGEM specifically excluded any schemes where there would be a possibility of pumped water - took waste water turbines out of it at one fell swoop.
I don't think anyone is trying to do anything unsafe or illegal, but we are a forum of diy types after all...
