I'll look into it. Should be able to get some handy tech backup if required ( which it will be..... ).Not saying it does. Don’t get me wrong. You sound like you make all sorts of very interesting stuff. I for one ,would like to see it. So, if you don’t post photos because of some sort or techie issue, fire away
No reason why you cannot post photos from your phone here, I do …
What actuates and releases the arms? Downwards pressure?Yes its here
I hope you do work out how to post images, your bike engine works sounds really interesting but if like me you were brought up on Japanese 2 and 4 strokes of the 70's and 80's it is difficult to imagine some of the things that you make or modify.I'll look into it. Should be able to get some handy tech backup if required ( which it will be..... ).
would nt a red fibre washer get chewed up under a valve spring ?Adjustment rings to enable B.44 valve springs to be used with B.33 base cups.
Got to TIG braze them together tomorrow, but they ain't so shabby.
Base insulating washer for the exhaust valve spring in red fibre as well.....
Balance of the lever point and mass on the sides of the gear, hidden by the front plate. Downward pressure puts a turning moment on the gears.What actuates and releases the arms? Downwards pressure?
Direct link into my 'phone ?Assuming that your page looks something like mine, click the picture button, then click in the middle, and then a page of pictures will come up to choose the one you want.
Not if the washer is sitting under the spring base cup....would nt a red fibre washer get chewed up under a valve spring ?
not drastic though only about a fiver .Its very handy being able to do that.Picked up some Wilson toolholders for the pressbrake, they're double sided to let you use tooling back to front which can be very useful.
They were designed for Amada brakes so i had to turn the top plates and mill the slot bigger to suit my Safan.
View attachment 442138 View attachment 442139 View attachment 442140 View attachment 442141
Looks as though I'd have to upload photos from my 'phone to my pc, and go from there....Direct link into my 'phone ?
