Cold stitching is far more reliable for engine repairs.Gents,
A good friend of mine asked me if I could repair his old tractor (Steyr 80 made in 1956).
The cylinder housing cracked due to frozen water. As best I know, the material is 'grey' cast iron. Wall thicknes is unknown, I believe it is somewhere around 10mm or more.
I got some 3,25mm OK 92.58 welding electrode made by Esab, but I've never used one.
My plan is to warm up the engine, then drain all the water. Then I try to preheat the weld area as best i can.. Badly, I have no oxy-acetilen setup, so I can only use a big propane torch.
I can measure the preheat temperature with infrared thermometer, but thats all.
I also have an AC/DC TIG welder, but a welder friend told me to use the electrode as it is.
By the way, the crack is around 60 mm long.
Has anyone experience with such a repair? Do you have any suggestion for the preheat temperature what I should aim for?
Thanks
Cold stitching is new to me, I need to look it up.Cold stitching is far more reliable for engine repairs.
Or Cast iron oxy-acetylene welding - but that's really specialist. Look at CIWS in Coalville.
Brazing but you'd struggle to get the block hot enough i reckon.
I wouldn't trust tig brazing on an engine block but that's just me.Cold stitching is new to me, I need to look it up.
My location is in Hungary, so Coalville is more than 3 clicks away sadly.
TIG brazing could work, but I don't trust its watertight permanently.
I know a man in Ogre Latvia who would repair it, Ramoto Ltd, Juris Ramba.Cold stitching is new to me, I need to look it up.
...you've got two companies that make the bits: Lock N Stitch and Metalock
A cold thread... Having difficulty getting a stitch repair kit for reasonable money, but I want to repair a cast iron engine block on an old tractor. I'm thinking of using a bunch of M6 hex grub screws—drill, tap, apply red Loctite, then gently touch the inserted grub screw with a carbide burr. Drill tightly so it locks into the previously installed grub screw... then rinse and repeat. Does this seem like a reasonable approach?Lock n' Stitch have a European site:
Bulgaria is only 2 1/2 clicks distant.
ReTech SD Ltd. - LOCK-N-STITCH
www.retech.bg
If you were really keen, you could make your own stitching kit based on copying one of the above.
I would use a slow set epoxy. Something like jb weld.A cold thread... Having difficulty getting a stitch repair kit for reasonable money, but I want to repair a cast iron engine block on an old tractor. I'm thinking of using a bunch of M6 hex grub screws—drill, tap, apply red Loctite, then gently touch the inserted grub screw with a carbide burr. Drill tightly so it locks into the previously installed grub screw... then rinse and repeat. Does this seem like a reasonable approach?
You need some locks though. It's alright screwing into the block as you say but the problem is stopping the block from cracking again.A cold thread... Having difficulty getting a stitch repair kit for reasonable money, but I want to repair a cast iron engine block on an old tractor. I'm thinking of using a bunch of M6 hex grub screws—drill, tap, apply red Loctite, then gently touch the inserted grub screw with a carbide burr. Drill tightly so it locks into the previously installed grub screw... then rinse and repeat. Does this seem like a reasonable approach?
