OJCar
- Lothian & Westmorland
Now I understand !Fool...
If you don't try, you don't find out....
You are B. A. Baracus and I claim my five pounds !
I've just remembered I found a fault on someone's Mitsubishi GTO that was over fueling, there was a damaged wire grounding one injector causing it to fire constantly. I ran a new wire bypassing the damaged bit and it all worked. It might be worth checking this.So injectors are fine I've tested them.
What's the minimum bore size for that?A pack of CCGT030101L-F inserts and a C06-SCLCR03 boring bar. The DCMT0702 insert for size, they are tiny!
When working if France, I did get nicknamed ' Hagler' by my French colleagues , but that's another story...Now I understand !
Did you keep arguing over prices?When working if France, I did get nicknamed ' Hagler' by my French colleagues , but that's another story...
No, it was something to do with my physique at that time.Did you keep arguing over prices?![]()
but the best bit of the day
Yep and i got the other pair...quality pair of clamps these as i have the size bigger too and they hold 2 bits of square stock exactly 90 degree for welding up, makes the job so much easierToday I acquired a little mac 1/4 dr socket
View attachment 440697View attachment 440698
in 7mm now all I need is an MG6 in unicorn 10mm and I'm to a full set .but the best bit of the day
a pair of HD welding clamps from @Paulbarrett . Not quite sure what I was expecting but these exceeded it
thanks Paul .
that's mineA new thermometer to replace my ruined one.
Listed as spares or repair, the plan was to swap the front of the case with my still functional melted one, but it turns out:
A. It works absolutely fine, just missing it's battery cover.
B. It's actually better than my old one, I had a 62 MAX, this is a 62 MAX + (And was listed as a 64)
C. The part of the case I was planning on using has been engraved with a number, which was carefully taped over in the eBay listing. Presumably the seller stole it from work and didn't want anyone recognising the asset number.
Yeah - some clown here was putting our missing expensive measuring gear on ebayA new thermometer to replace my ruined one.
