- Birmingham
My local BOC branch used to have an acetylene cylinder outside the door that had split top to bottom and opened up. It had some kind of honeycomb structure inside it.
Did they use O/A to section it?
I think they use/used Kieselguhr, a white clay.Back in the 70s it was acetone and charcoal. Don't know if that has changed in the passing years.
So the solvent allows it to be 200psi in the bottle then?
How does the gas drawn off into the regulator at 200psi, not go bang, if it decomposes above 28psi?
No it had blown up. They put it there as a warning
Acetylene is one that can react without oxygen.Not much will burn/ignite without the presence of oxygen and with o/a that is at the welding/cutting tip.
Bob
Its most singular hazard is associated with its intrinsic instability, especially when it is pressurized: under certain conditions acetylene can react in an exothermic addition-type reaction to form a number of products, typically benzene and/or vinylacetylene, possibly in addition to carbon and hydrogen.[citation needed] Consequently, acetylene, if initiated by intense heat or a shockwave, can decompose explosively if the absolute pressure of the gas exceeds about 200 kilopascals (29 psi). Most regulators and pressure gauges on equipment report gauge pressure, and the safe limit for acetylene therefore is 101 kPagage, or 15 psig.[54][55] It is therefore supplied and stored dissolved in acetone or dimethylformamide (DMF),[55][56][57] contained in a gas cylinder with a porous filling (Agamassan), which renders it safe to transport and use, given proper handling. Acetylene cylinders should be used in the upright position to avoid withdrawing acetone during use.
Copper catalyses the decomposition of acetylene, and as a result acetylene should not be transported in copper pipes.[62]
Acetylene doesn't burn, per se. It breaks down into its constituent parts: carbon, hydrogen, and oxygen. But it does it very angrilyNot much will burn/ignite without the presence of oxygen and with o/a that is at the welding/cutting tip.
Bob
Copper nozzles?And don't under any circumstances pass it through copper pipe.
I disagree. The pressure is limited by the volume of the cylinder and the ability of acetone to absorb acetylene.That is in air. Within the cylinder, and in the absence of air/oxygen, explosive decomposition can occur above 250 psi. That is why the cylinder pressure is limited to 250 psi.
I disagree.
Acetylene does not need oxygen to decompose.
No, this is a 22RB:is that an RB22
The UK side, Ruston Bucyrus, were a major employer in my home town of Lincoln. They started as an offshoot of the local engine manufacturer Ruston and Hornsby. In the 50's the cranes and draglines going for export were proudly paraded through the streets of the city on low-loaders, sometimes in huge crates.Interesting about Ruston Bucyrus......Apparantly a licensee of Bucyrus Erie.
Main plant was in Millwauki area, but had one in .....wait for it ....Erie.
Saw many cranes and shovels rolling out the big door as a kid here
The quote that posted with the comment.With what specifically?
Google will help you out.The quote that posted with the comment.
Do they weigh all the cylinders when they refill them and top up the acetone first?
I realise it was posted earlier. I repeated it because topping up the acetone makes it accurate. I should have noted "as stated" - sorry about that.Liked. Just as per the reply 36 postings ago.![]()
