Looks like a nice lathe job, turn the outer profile and bore out the centre, then it just needs cutting in half and the half a hole filing out to a triangle.I want to make some new threaded clamps to replace this rubbish U bolt thing. 11mm deep 45 degree to cut out, looks like I am doing two of them by hacksaw and file!
Yes that may have been a good idea, cut two halves and bore out together, but I did t see your message and dont have the chuck fitted on lathe and Im very lazy about swapping it.Looks like a nice lathe job, turn the outer profile and bore out the centre, then it just needs cutting in half and the half a hole filing out to a triangle.
It looks way bigger...Just made a 20mm riser from a piece of 2.5" x 2" x 130mm 6082 which, once anodised, will be winging its way to Aruba.
First op.
Flipped over and second op done.
Do you have a link for that?Like using these bars, they always cut nicely and give good chips.
The OD measured 29.98mm so bore turned the same to match.
I think I have the same bars but don't think I have got any tips for them yet. LolDo you have a link for that?
I need to get some new boring bars. My little 8mm one is just too springy.
Yes but for boring steel its important the inserts work well, I found it difficult to get good ones to suit boring and the ones above were luck.Do you have a link for that?
Remarkable coincidence you just posted these.Yes but for boring steel its important the inserts work well, I found it difficult to get good ones to suit boring and the ones above were luck.
I have a spare one I rarely use - the DCMT inserts I have dont work particually well at the different angle it uses. I'll get a photo if your interested, its a Korloy C08K-SDQCR-07.
The good ones above are SDUCR which is excellent with that style of single edge chip breaker. The APT inserts are not available anymore tho I have a few spare if you do get a SDUCR I can send a few, they last a long time.
I have one of these, min bore about 10mm. cCMT inserts
However the 8mm is probably same min bore so get that instead
Or SDUCR07 /11 like my ones above.
Ah, that makes more sense than your Insta postMachining Thin wall tubes again. 1,78mm od, 1,7mm Id. 8,5mm long out the shytest grade of mild steel available, 1010. Now to drill four rows of 5 holes around the circumference.Then I need to nickel plate them as no plating shop has the balls to plate them, let alone make them
View attachment 437894 View attachment 437895
