julianf
- devon, uk
Im after a cheap central locking kit to do the doors, but i also want another output to latch a relay (for a pre-heater)
Ive found this kit, that seems to do the job -
( https://www.ebay.co.uk/itm/355003876427 )
Its one of the few that actually gives a wiring diagram, which is a bonus, ut not when i have no idea what
1) connect with manual is,
2) what "siren" does (i mean i know what a siren is, but this is a locking kit, not an alarm, so im unsure)
and
3) how the diagram doesnt end up disabling the indicators (ie they would then both flash at the same time always)
Further, but not as important - i assumed these kits had one motor with feedback (im assuming "anterior motor" in the diagram, that was on the drivers door) and then a load of slave units (any idea why, what im taking as slaves, are called "poster" and "master")?
It seems that the kit will do what i want -
press the lock button, doors lock
press unlock, doors unlock
press and hold any button, trunk release goes live (which ill wire to my latching / timer relay, one of these or similar - https://www.12voltplanet.co.uk/adjustable-delay-timer-relay-delay-on-or-off-12v-10a.html )
(or better yet, press the trunk button, as then i get the light flash to prove that its received the command, and the heater is on)
Basically, id rather know the details on the item before i buy it, and im hoping someone here can assist me to understand it in full! : )
Thank you
and
Thank you
