Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Depends if you're running a multifuel engine.
I believe they are turbine engines now.If we are talking about military tanks, I understand they can run on just about any liquid fuel.
Gas Turbines will run on most fuels, its normally a requirement for most military engines, especially battlefield ones.I believe they are turbine engines now.
They are generally multi fuel engines, not 100% sure how that works but.............Nick Mead at Tanks-a-lot near Silverstone. runs his tanks on miss fuel, does them no harm.
Only the septics use turbine packs in the Abrams, not a particularly solid choice by all accounts, and they aren’t overly keen on sand. British challenger uses an MTU diesel I believeI believe they are turbine engines now.
I run my truck on miss fuel it's a mixture of petrol and diesel from a recovery company. I used to pay 50p a litre but now with less and less cars able to run on it I get it for free. I've filled up my holding tanks and iam getting more than I use, so I was thinking of running my central heating oil boiler on it. Anyone tried it ?
One of the biggest issues with putting petrol through a diesel is that it destroys the lubricity of the diesel and ends up shafting the injection pump.
My injector pump is pressure fed with engine oil.One of the biggest issues with putting petrol through a diesel is that it destroys the lubricity of the diesel and ends up shafting the injection pump.
Its the petrol that would worry me. Seems an odd thing to run through an oil boiler?We are on page two, and I'm not sure if I've seen anyone actually try and answer your question yet?
So, kerosene is 28sec (measurement of viscosity)
Diesel is 35sec
Who knows what petrol is...
Basically on a pressure jet central heating boiler the pump pressure and jet size are set to the viscosity of the fuel (and intended burn rate).
I mean, virtually all boilers now are 28sec only, but on the ones that can be configured to run on 35sec, this is how it's done.
Your misfuel will be constantly changing, but you could make yourself a viscosity cup to measure it. You could calibrate an unknown cup with known fuel at a known temp and then work from there.
Modern burners are quite, umm, safety conscious, in that their start up cycle runs the fan for a while before ignition, in order to vent the chamber of any residual fumes (that could be explosive).
I would suggest that, providing you took sensible precautions, there would be no issue.
Obviously, if your house burns down (for an entirely unrelated reason) and your insurance sees the IBC of misfuel wired into your boiler, you will have to figure them until long after your own death for any sort of payout at all, but, other than that....
Currently one of the biggest issues with hydrogen engines.One of the biggest issues with putting petrol through a diesel is that it destroys the lubricity of the diesel and ends up shafting the injection pump
It would be, it ran at 45,000 RPM! (iirc)I once bought a Rover 1S60 whilst testing wine and browsing e-bay.
Noisy thing, ran fine on heating oil as I had no avtur.
Sold it to a loony who wanted to power a car with it.
I remember a lecturer telling us a gas turbine would run on pulverised coal, just not for very long.Gas Turbines will run on most fuels, its normally a requirement for most military engines, especially battlefield ones.
Yep, the problem is pumping it.I remember a lecturer telling us a gas turbine would run on pulverised coal, just not for very long.![]()
