What's your thingiverse handle @fizzyNo other nozzles yet. I did post the link to it on thingiverse. There are some newer edits of it with battery compartments etc built in.
Not registered on there yet. Not my design.What's your thingiverse handle @fizzy
but I have now fixed the stringing issues I was having
It was a combination of too high a temp (210) and not enough retraction for the long Bowden on the E5.What was the cause & cure?
Thats an impressive looking thing, what is it?Biggest print yet on the Jupiter - 19hrs in, 6hrs to go...
and more from the same project, some 'knurled' M18 nuts and fittings...
It's part of a mould.... there's a high chance it won't work so didn't bother sharing too many details.Thats an impressive looking thing, what is it?
Nylon 66 blend is worth a try otherwise. I have a roll of Overture Easy Nylon that you could borrow to make that.Worm gear for my bandsaw next to the rather destroyed original
A quick fit shows it fits ok but I'll have to wait until I can put it back together to see if it's up to the job. Printed in abs 0.8mm nozzle.
Loose nozzle?Nothing on the Ender 5 for a while. This is my new £60 all metal hot end![]()
I have no idea. It was printing fine, put a new reel in and this happened.Loose nozzle?
It has annoyed me somewhat as I don't know why.
I have ordered a direct extruder, it sorted the problems on the E3 so hopefully it will help with the E5.Looks like a typical issue with the bowden tube adaptor.
Here is the fix: #16
TLDR: fit a short length of perfectly fitting bowden tube into the hot end before connecting it up...
