brightspark
- yarm stockton on tees
looks like its its a suction gun .over priced and not much cop
what was the "shot" ?Good evening all,
So today I received a 90 litre cabinet and tried out some shot on a couple of parts. The setup was simply just my 200 litre 3hp motor compressor with about 9-10CFM FAD. I used a 5mm tip.
It wasn't bad to be honest. Obviously the compressor cut in early and remained on unless I gave the blasting a break.
I would be happy that by adding extra capacity and the other 3HP motor that I would happily blast parts in the cabinet... keeping the duty cycle etc in mind.
Now, for the chassis / ladder frame chassis I was thinking of doing. I have concluded that it's probably most economical to rent out a large >100CFM unit.
Get as fine as you can.
it's not like sandpaper, fine will get into the deep pitted corrosion better.
finer also means more abrasive per second is going thru the nozzle.
The life span of the grit.Ok, interesting... with that in mind.. I think that this "shot" is definitely on the finer end of the scale.
What differentiates some media from being suitable and unsuitable for blasting cabinets?
if and i say iffThe life span of the grit.
Aluminium oxide gets smaller but stays sharp during use and when it's done it comes out in the dust extract. You top it up with fresh and you get a media that can both get into pits and still knock flakes off. Leave the little black pits around unpainted for a day or two and the rust grows out of them like spots of mould.
At the Silicosis end of things kiln dried sand is very poor to start with and the second time use doesn't make a noticeable impression.
Ideally your line running to your filters should also be 1.5 times or more larger than the line out that feed the pressure pot or spray gun etc. Minimise restrictions in your airline. Pic of how I made my propane cylinder.
I have one of those pressure pots and great for the little jobs I do but the nozzle and valve wear quickly so you’ll most likely need to upgrade those.
If you can a diesel compressor could be the easiest solution.
Regarding expanding the business have a look into rust proofing, there’s a shortage of folk doing it up here and if you set it up properly could be a nice earner and go well with the media blasting side. These guys are a good example: https://preserveprotect.co.uk/ and have a look at dry ice blasting for cleaning the underside of cars, that’s another thing that I think would go well.
We use garnet, no idea why but just throwing it in the ring as a potential option.
Sorry if its already been mentioned. Not sure if you still intend to use gas bottles, but if you are and don't want to weld fittings it is possible to set them up with a small tube to the bottom of the tank and have it come out through the centre of your fitting on the top to drain them.
Sorry don't remember specifics as it was a while ago, but sure I saw the idea on this forum.
I used 15 copper with a 10mm airline from the filter to spray gun but I really only spray paint. You should be looking at 22mm at least or larger I would think. Or large hose.Interesting yes. I was only thinking the other day that I will try and use something decent for the "ring main".. what size did you run?
What is your hunch on cost vs benefit of a diesel compressor versus the 3 phase I mentioned above?
Thanks for input on the business side of it.. Maybe I failed to mention.. the primary objective of the blasting is to perform good rust prevention / underbody sealing as an all inclusive service.
This evening I cleaned the shot out of my cabinet and gave garnet a go.. some 80 mesh. I was very happy with it.
It's all good.. type away, thanks
I do intend on using and rather not weld the pressure vessel itself. I need to investigate what fittings I can use. To be honest, I would probably turn it upside down and support it by welding to the collars on top and bottom, and not the vessel itself.
If the guy can’t Tig weld just get someone to Tig weld on a couple of bosses. It‘s a 5min job so won’t cost much and the best solution. I washed and washed my bottle out with soapy water and bi-carb as I use it for my air fed mask, there was no smell so it can be flushed out.Here is a thread with a bit of info and photo of what I was trying to describe.
Propane cylinder water drain-Problem solved
Faced with the old problem of how to drain condensate from a propane bottle air reciever I have come up with a solution. I removed the valve and replaced it with a 3/4 BSP nipple, on to this I fitted a 4 way 3/4 BSP cross fitting. Into the top of the cross fitting I put a 3/4 - 3/8 reducer and...www.mig-welding.co.uk
I cut the handle off mine and welded some legs to it, haven't had any problems, also gave it a coat of paint and it is hardly recognisable as a gas bottle.
It is worth mentioning that even after filling the tank with water and letting sit for a while, when you start using it the air does smell of 'gas' for a while, seems like the smell gets into the metal??
Yep, not sure if it was you or not, but I did see bicarb being mentioned to remove the smell, obviously only seen it after doing mine!If the guy can’t Tig weld just get someone to Tig weld on a couple of bosses. It‘s a 5min job so won’t cost much and the best solution. I washed and washed my bottle out with soapy water and bi-carb as I use it for my air fed mask, there was no smell so it can be flushed out.
I have no experience paying for a diesel compressor but the benefit is plenty of air if you want to expand the business. This type of work I think you need several vehicles on the go to bring in the revenue. Cars can be at different stages of the process and you could end up employing a couple of folk so working at the same time. I suppose think of the end game a bit when looking at what's required.
Good stuff on the rust proofing business, I think it's a good idea which can be expanded.
If you go at this full time consider what happens to the dust laden air in that building .
A road drill comp does not need a tank just a BIG filter and a big hose.
Beware of farmers, dung is very corrosive and I wouldn't ever buy a Rangy from one. Expect quite a bit of extra work compared to a Chelsea tractor.
