conor1n
- London/Ireland
Hello all,
I am currently trying to figure out the feasibility of setting up a compressed air system for some abrasive blasting.
My goal would be to be able to perform the following tasks (not concurrently). My aim is also to have a sustainable build, so I don't want to be labouring the motors/pumps too much. I want the system to be able to keep up. I really don't want to have to wait around for it to catch up after a period of time.
* Subframe blasting
* Possibly ladder frame chassis
* Car / Van underbody
* Smaller parts in a cabinet using dry shot.
* Vapour blasting using slurry in another cabinet
To start off, these are the types of tools I would plan on running:
* Blasting pot - 6-25 CFM requirement - 4 nozzles 2 to 3.5mm
* Blasting cabinet - 6-25 CFM requirement
What size is suitable if doing a subframe..... so that it's time efficient?
I have a figure in my head that I would like to achieve 20-30 CFM.. that's just finger in the air.
I currently own these compressors:
* Shamal 200 litre 3HP 220v with belt drive motor.
* SIP 50 litre 3HP 220v with direct drive.
I also have the following:
* A DIY air dryer - It seems decent as it removes a nice bit of water. I never noticed any moisture related issues when I painted my car with VOC paint. I would be happy to build another one with improvements on my first build. (I have since removed the quick connects on this for airflow reasons).
* A local friendly gas supplier is willing to give me a couple of 47kg gas tanks which are approximately 100 litres each. I am aware of the dangers of compressed air and I won't tamper with any of these vessels.
Some basically.. that's a total of 6HP and approximately 450 litres of capacity.
Thoughts:
I don't know how flow is calculated? And where FAD vs pump displacement comes into it. But the pump displacements of the two compressors above is 14 + 13.8 = 27.8 CFM.
Where does FAD come into it? Would the above numbers work for blasting?
Obviously there is the plumbing and wiring etc to be done.
* From research online, I would plan on plumbing the two propane tanks to the compressors. The idea would be to run the compressors with open and regulate after the receiver tanks.
* I would also add in the air dryer, and possibly another into the mix somewhere.
* Interested in thoughts on how to set up the motors. At a minimum, I wouldn't want them both kicking in at the same time. Is that best solved by using a time delay relay/switch? Do the switches on most pumps have a little delay trimmer switch? I saw online that you can get an alternating relay.. so each time the pressure drops the alternate motor will kick in, this will help with duty cycle and also help spread the wear evenly.
* For draining, I would like some kind of automated drains on the cooler and also the bottom of each compressor. I would plan on putting all this gear on a mezzanine so I could easily plumb all the various drains together and then run a line down to floor level which I could manually release or put a switched drain on it.
Interested in peoples thoughts, especially on the CFM side of things as this is something I don't know how to calculate etc. Actually can I ask a question.. is it the case that the pumps ultimately provide the CFM rating of the system.. and the tanks are just used to increase capacity to prevent overworking the pumps.
This was a long post... if you got this far, thank you for reading
* Subframe blasting
Thoughts:
