Won't work with air. Meant for liquid, hydraulic oil probably.Forest of Dean household recycling centre.
Now, what am I doing to do with it? Scale is way off for my air system? Steam punk
Will that really pull up M10 rivnuts?View attachment 425662
Combined pop rivet & rivnut gun, & nibbler, (or reamer, as they refer to it, but it's a nibbler, in my view).
Going to have a play with it later.
Spec's from the box cover for nut & rivet sizes.
Nice weight, & initial once over, everything seems sturdily made.
Will that really pull up M10 rivnuts?![]()
It'll work exactly the same with air as it does liquid.Won't work with air. Meant for liquid, hydraulic oil probably.
Thats a nice bit of kit, what models does it list in the General Motors section?Today I acquired a very nice fully adjustable Blackhawk chassis measuring/ holding jig, came with a box of locating/holddown tricks and a load of no use to me chassis data sheets. This is going to make very easy work of a few projects I have on the go.
Bob
View attachment 425689View attachment 425690View attachment 425692View attachment 425691
That was a lot of money in its day and still a very nice bit of kit ,I wonder if you can get up to date data , wouldn't be sheet though .Today I acquired a very nice fully adjustable Blackhawk chassis measuring/ holding jig, came with a box of locating/holddown tricks and a load of no use to me chassis data sheets. This is going to make very easy work of a few projects I have on the go.
Bob
Did you the big box steel frame that the measuring jig sits on as well ?Today I acquired a very nice fully adjustable Blackhawk chassis measuring/ holding jig, came with a box of locating/holddown tricks and a load of no use to me chassis data sheets. This is going to make very easy work of a few projects I have on the go.
Bob
I'll find out later.
It should manage M10 aluminium rivnuts fine. Probably be a lack of leverage to do steel ones though.
Cannot see anything forToday I acquired a very nice fully adjustable Blackhawk chassis measuring/ holding jig, came with a box of locating/holddown tricks and a load of no use to me chassis data sheets. This is going to make very easy work of a few projects I have on the go.
Bob
