Out of interest did you test the replacement battery with the topdon??When failing car batteries throw in the towel.
My Dad's 2015 MB was on its original AGM battery and it went kaput.
New battery got from the dealer - fresh 40th week 2023 production.
Should be case closed for another 8 years.
I have a similar tester checked my 2011 plate skoda May be original showed 90% health but I've seen new ones less than that.
If you retest same battery it gives similar results each time.
My 100ah 950 amp crank battery shows 30 % but starts the 1.9 diesel fine often running 80 amps of heater plugs
I actually have one of thee very old Durite load testers and some of my " retired" batteries still hold good (>9v )after 20 to 30 seconds and a pretty red element.Very timely thread Joepro, just this morning on the way to work in my Vw T5.1 van the battery light came on!
I checked it and its only 11v, the worrying thing is it is still 11v when running and rev'ed. I've gone and bought a new battery and am really hoping it's not the alternator.
The van is a 2010 and this is the original battery!! (I have had for 11 years, so I wouldn't have thought its was changed before I hab it)
Before this van I had 2001 Passat that I sold at 12 years old and that had the original battery on so these VW factory batteries are pretty good!
My BMW bike had a new battery last winter, and a few weeks ago the charge light stayed on after i'd fired it up. I shut it down, as it was quite late and it was a bit loud, and next day got my voltmeter out to see what was going on.Very timely thread Joepro, just this morning on the way to work in my Vw T5.1 van the battery light came on!
Don't forget vaseline for the battery posts.Yep replaced the battery on my car a few weeks ago.
Bloody battery clamp was seized solid.
I Had to chisel a chunk out the old battery to get it off.
Won’t happen again though… new battery is held on with a ratchet strap… job done!![]()
