Hopefuldave
Intergalactic pot-mender
- The Shed of Danger, surrey, England
https://fordtransit.org/forum/viewtopic.php?f=4&t=34736 suggests boltin is ok for the MOT as they're not structural
yep tomorrow, once the passenger side is done i will look at the drivers side in the spring, a quick look tells me its not anywhere near as bad.You have done well mate, but it is a transit.
End this episode with the immortal words of the big man,,,
"I'll be back"
Agreed. I literally learned to mig weld in order to repair repairs made by "professionals" on my old Capri. Best thing I ever did and my first repair- inner sill/ floor pan edge and outer sill tie in was better than any of the "professional" repairs. I had two different professionals work on that car before I re-did it myself. Only a few of their repairs remained. Some had to be cut out and re done, others I ripped off with locking pliers lol.some people can weld fine but are terrified of welding on their vehicle. dont assume.
also to be fair, have you seen the quality of welding done by 'professionals'? because i have, and you cant possibly be worse than that.
Indeed - the prep and weld type can make a huge difference to penetration and strength. I prefer not to butt weld panels - its hard to get a consistent bead (means I'm rubbish I guess). Instead I like to overlap by a mm or two, melting the overlap into the base metal - means you can run higher amps without risking burn through.You will be surprised how quickly you get the hang of it.
Push yourself with the type of repair you want to see.![]()
well things are moving on, have a look at how far i have come to date, i still have a few bits of welding to do here and there, once done i will treat it with hammerite kurust then spray undercoat then red led and finally underseal, i forgot to mention that seam sealer will be the first to do on my list once i have ran the grinder over all the welds and flatened thiem.View attachment 421078View attachment 421079View attachment 421082 View attachment 421080 View attachment 421081
Hoping we hadn't! Looks like you're making good progress, well done.just when you thought you had got rid of me.......
cheersView attachment 422604View attachment 422605View attachment 422606
well its a long term project and this is our way of getting away, i bought it in august and stuck it in for a timing belt and water pump and even with a good mot i new work would be needed to keep it on the road so off i went with my eyes wide open, come spring i intend to start cleaning off the chassis and give it a good clean up, as of now i can see one small area thats needs a weld but nevertheless the rest will still get cleaned off and sorted.Hoping we hadn't! Looks like you're making good progress, well done.![]()
not sure what you mean by bonded in, i gather its like any other mk5 with the sealent placed around the inner lips of the windscreen then the windscreen placed into place and pressed against the sealent with the rubber edging being pushed into place around the edges, is there any other way it would be put in?.Hard to really see, but that looks like a lot of work. Is the screen bonded in?
