DAPPH
as dyslexik as I'm daft
You may have your Tickers in a Nwist thinking that .Let’s be honest 4kW+ is exactly the same as that same amount of heat from another source. If fitted properly, with proper and adequate insulation, along with effective draught exclusion, I would expect the space would be heated within a reasonable time period.
On the other side, if heating cold blocks in a leaky (poor insulation, leaking air) garage (uninsulated steel door(s)?) drawing in combustion air from inside and cold (to be warmed) from outside - one cannot expect them to warm the space efficiently.
Burning half a litre (some don’t even deliver the full amount claimed) requires a given volume of air. Drawing in cold air from outside would be horrendously inefficient ax the same amount of warmed air must leak out.
Think or research Spitfire 's impressive gain in max speed by spray injection of plain water in the air intake, the water cooled the ingoing air thus making it more dense therefore richer in oxygen for the given volume . Which in turn assisted in a better more efficient burn of the fuel that gave the amazing increase of power.
