Laurie Tedcastle
- NW Northants (UK)
Paul (our wonderful recently deceased moderator) used one of these in his business and it had quite a lot of use. I don't think hinge wear is normally a problem. It's for sale on here.If it's set square now and I don't adjust anything the only real variable must be blade wear surely? In which case if I notice any difference in cut speed or quality I'll have a spare blade from the same supplier on hand and swap it out.
Again for all I cut it will be years until I get to that point unless I break a blade!
If it was used every day in a business environment then I would agree its not built for that and would likely have other long term wear issues as a result like hinge wear and would require further adjustment / maintenance to counteract.
Laurie
