check the main drain at manhole cover outside might be blocked or backing upwater slow to depart bowl combined with gurgling from shower plug/drain.. tried the normal things and used a 3metre long flexi pipe cleaner but found no real resistance tbh .. Any ideas what i can try next … pipes are all behind tiles etc
give it a good rogeringIs the problem one on ground floor and other upstairs?Ok will do .. 2 bathrooms in our house and only one with the issues.. if that helps ..
Yes it’s one upstairs and one down… the servants quarters are downstairs…Is the problem one on ground floor and other upstairs?
We had similar sounding issues, downstairs toilet was backing up and very slow to drain. The backup was caused by water coming from upstairs that couldnt get out, so the bog level rose.
We had a tree root invade the manhole and go up our outlet. A poke with shovel and plenty of water cleared the problem.
At the mo no idea i’m afraid …Does it have an atmospheric vent, or is it one of those air admittance value things, they sometimes stick
have you a vent stack sticking up outside house, if not might have the air admittance valve insideAt the mo no idea i’m afraid …
for water todrain freely, the system needs to breath or let in air as the water runs down creating a vacuumAt the mo no idea i’m afraid …
