Yup, I have one, my family has always had gas dryers.think they need outside ventilation and presumably a gas safe installation and associated pipework and costs. Plus haven't seen a domestic one in years but get your logic on price once installed
White Knight factory in Lightcliffe (ex Crosslee, ex Philips) is now in the process of becoming a housing estate . . . so I'm going to guess you won't see many more . .White Knight are the only domestic ones I've ever worked on but I haven't seen one in years except in the gas training centers.
Remember though that gas is typically 1/4 the price of electric so even if the heat pump is working well it won't be as cheap to run.parents had a gas tumble tryer when I was growing up, worked well, but I remember it being hard to get one when they wanted a replacement
must have bought the first one when I was a kid because I can remember helping my dad run the new gas pipe through the cellar to it, so they probably used them for 20 years
but... I think a heat pump dryer is probably cheaper to run because it's a sealed system, no ventilation in/out of it, just a dehumidifier connected to a spinning drum, a gas one constantly blows hot air out
I've got a heat pump one at home, no idea how much it costs to run, running that, a washing machine and 8amp car charger all on the same 16amp feed
That's alright up until the gravity sprinkler starts upOur drier is wind powered
The unseen benefits of owning a car portThat's alright up until the gravity sprinkler starts up
Used to design industrial ones in a previous life - usually needed a hint of heat in there too.Given that the boiling point of water reduces with air pressure; why not make a vacuum dryer? Plenty of old vaccum pumps kicking around and I'm sure some old calor gas bottles could handle sub-atmospheric pressure?
the gas type can heat air coming in from outside whilst swapping the air from the insidegas is 1/4 the price of electric but they're not doing the same thing?
gas tumble dryer is blowing hot air out the exhaust the whole time
heat pump dryer is a sealed system
