I know nothing about that, but might bé able to heip.
, I thought you worked on boats.The little plastic shelving unit looks likes it’s holding a bit of weight too!
it's fixable if you know a rewinder
I did rear on the the missus Mk7 Golf this year, what a faff.....simple 2 piece plate would save hours of workRears today, first a check I had the correct tool to get the hub off. Bought years ago for an A3, it fits.
Taking the rear caliper off is a pita on the golf with electric parking brake, diagnostics tools required so I decided to try to take the brakes and disk off together without releasing the parking brake.
Held on with two bolts.
The whole lot came off together and got tied up. On to the very tight hub bolt..
Looks like the heat shield is held on with the stub axle bolts.
Old shield off.
New one back on.
Bolted back up and on to the other side. Both sides done in ~ 90 minutes.
![IMG_3843[1].JPG IMG_3843[1].JPG](https://www.mig-welding.co.uk/forum/data/attachments/415/415999-ee5bd2cbfb5647136635b1e0898e74b8.jpg?hash=7lvSy_tWRx)
£1000+ for the toolHave a question associated with this.
Regarding part circled in red. Say if I wanted 100 of these pressed out. What would I be looking at for unit cost roughly and tooling?
Dont you have to cool the case before filling to get the Bellows contractedMy NATO Marching Compass ( 6605-99-531-250 ) has sat in a drawer for decades - mainly as it had a large air bubble in the damping fluid. I did pull it apart decades ago and top it up but eventually it again developed a big bubble.
Well now we have Goggle I unleashed a suitable search to find that this model was only made for about a month AS IT DEVELOPED BUBBLES
I thought I'd have another crack at it today - eventually got it apart - taking out far more screws than were necessary, and topped it up got it back together. Apart from the fact that it's outer (none sealing) glass is cracked and the rubber base ring is a bit perished it's back in working order - for now at least.
So - all you have to do is gently lever off the brass rotating bezel (the bit where my glass is cracked), remove eight underlying screws and lift the sealing cover glass off. Gently lift out the mother of pearl magnetic card from its pivot, top up the fluid (I use cigarette lighter fluid) to form an upwards bulging meniscus, replace the card, again top up to an upwards meniscus, and re-fit the cover glass and eight screws without introducing air bubbles. Below the pivot assembly is a bellows, so as the glass cover is pressed home the excess volume compresses the bellows and with any luck you are good to go.
The brass bezel is retained by a spring clip that sits in a suitable groove in the brass and in the body of the compass - same system as is used for DTI's face glasses.
No during' pictures - I forgot - but here it is finished.
If anyone has a spare rotating brass bezelled outer glass please get in touch
View attachment 419689 View attachment 419690 View attachment 419691
Hot pressing?£1000+ for the tool
If I remember correctly (?), it was an engine driven deck washdown pump, of which I have zero experience, we have a bloke who washes our boats, he's great.I know nothing about that, but might bé able to heip.
I thought the first photo was half a banana.View attachment 419717
Got this pretty sorry mini Sheffield sheath knife from a junk shop. It was all loose a r someone had had a go peening the end of the tang.took it apart straightened it welded an m4 screw io the end of the tang. Made a threaded brass bead reassembled and cleaned it up
Just needs a sheath now.
Aye my photography leaves a bit to be desiredI thought the first photo was half a banana.
And the rest! That's a pretty deep part, it would need progressive stamping so you're essentially buying several tools in one. You've got to pay someone to develop it, manufacture the tool, probably manufacture a second one when the first version cuts undersize, and finally pay someone to press them out (A day to set it up on the press + 2 minutes to make 100 parts). I think you'd be doing well if you got the tool made under £10k.£1000+ for the tool
A tool that simple isn't going to be more than a £1000 - he wants to make 100, not a thousand parts. Now if you said it needed to make 100 parts a year for the next 10 years you might look into commerically made dies of fancy tool steel and grinding it to dimension. A bog standard tool steel with a turned finish then polished will work.And the rest! That's a pretty deep part, it would need progressive stamping so you're buying several tools in one, you've got to pay someone to develop it, manufacture the tool, probably manufacture a second one when the first version cuts undersize, and finally pay someone to press them out (A day to set it up on the press + 2 minutes to make 100 parts). I think you'd be doing well if you got the tool made under £10k.
100 is an awkward quantity to make. Less than 10 it might be viable to turn them from solid (Or cored bar), or fabricate them. 1000+ it starts to become worth getting a stamping tool made.
I'd consider approaching the supplier of the drive shafts and seeing if they can sell you just that bit.
Metal spinning. Still over £2000 for the job i reckon. Die would be £500 minimum.That's annoying. Any cheaper routes?
