Wildefalcon
- Gloucestershire, England
Around 25μF
Well, the plot thickens..... The capacitor wire came out. As in came loose when I was writing it all up.
So, was the cap dead? Anyway, the connector is crap, rusted screw.
Some photos of the pristine rotator, and the offending board...
View attachment 419338 View attachment 419339 View attachment 419340
Yes, it looks horrendous but it'll do for now. Later on i'll remake the entire thing with a new bottom tray ready for running coolant.
The shelving unit in my garage is allegedly capable of 265kg per shelf but sagged that bad under 30kg engines I had to slip odd bits of wood and steel under them to stop them falling through.
The shelving unit in my garage is allegedly capable of 265kg per shelf.
No sagging now, even with at least 100kg on each shelf, sorted![]()
Some interesting toys there.The shelving unit in my garage is allegedly capable of 265kg per shelf but sagged that bad under 30kg engines I had to slip odd bits of wood and steel under them to stop them falling through.
Before
The original 9mm chipboard shelves, see how bad they've bowed
I was having some wood delivered for another project so added a sheet of 18mm ply to the order, a bit of circular saw action produced these...
I know nothing about that, but might bé able to heip.Those are the ones that will fit on a shelf
I was going to contact you next year to pick your brains on marine installations for my current project, a Stuart marine lighting set.
I know it's a marine set as it has the optional "deck wash" pump fitted.
