I prefer oxy torch in this case, pre-heat extra long, and watch the red area stretch, and relax the tension, then hit theI had a scrap car I had to get rid of in a hurry as the lorry was booked and all.
I wanted the Sportline Control arms from the w124 coupe so I sat in the engine bay and cut the coil springs with my plasma
I lived to tell the tale. There is only a small witness mark in the tarmac too.
My dad had a spring compressor snap doing xjs springs. It (the spring) hit him in the head and knocked him over backwards, then continued up to hit the roof of the unit. I wasn't there at the time but the guy who was told me he thought he was dead as he was not moving and pumping out blood from his head.Many moons ago I was after some XJ jag suspension for a car, scappy pulled a car out of the pile and put it on its roof for me. Got undoing the front lower spring platform bolts without the use of a spring compressor, the platform shot back sheering the remaining bolts and the spring whistled straight past my lugs, not so sure the spring landed in the same county.
Bob
Possibly a lot easier if you wound down the adjuster rings. It looks from here that the body is threaded all the way down .
Found that photo I may be a little mad but not totally.Possibly a lot easier if you wound down the adjuster rings. It looks from here that the body is threaded all the way down .
You sound like your a hazard (a walking one at that) to be around....YIKES !Found that photo I may be a little mad but not totally.
Pressed a 1/2 shaft out of a hub on a 1930s Hudson axle 35t it went off like a 45ACP the shaft hit the concrete floor (big divot in floor) took off cleared the Chevy fleet-master next to the press and out through the WS window after another bounce now that was scary.
I was at a shop where a woman was assembling some parts, they had a German made hi-pressure power supply running a bolt stretching device.Workmate & I were within 2' of a foot long / 4" diameter hydraulic filter that disintegrated at 2500psi. There was a bang and somehow the shrapnel missed us. Then there were a few miliseconds, seemed like minutes as the column of oil hung in the air...then gravity took over and splosh, everywhere. That was a testicles, spectacles, wallet and watch checking moment.
Turns out the original installer had fitted a low pressure, aluminium casing filter on the high pressure side. The part makers had incorrectly labelled it as high pressure.
