The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Last two, last cookies, last doughnuts.
From this.
This was fun.
From this.
This was fun.
Rice cooker placed on top of hot hob...melted foot.
Replacement foot made. Should keep wife happy. She's only "cooked" three rice cookers so far.
The back's under compression during the cut stroke, same reason lorry chassis crack on the top.Nice fix.
Odd place to crack on the back?
Would expect the frontside, because of cutting force?
From this.
This was fun.
Which one?What methods did you use to tidy up the square?
Which one?
The lower one, it was badly pitted.What methods did you use to tidy up the square?
Aged 6 I was given a new folding 3ft rule (as well as my dad's dad's claw hammer with a new handle). I still have the rule - it just doesn't measure 3ft very accurately 47 yrs later . . . (claw hammer still works well though - was using it last sunday)I've still got my Dad's square as well as his yankee ratchet screwdriver and folding 3 ft ruler somewhere in the shed
I bought a pair of old fog lights for my Saab, only 10€. When I get them I can see they say Bosch Halogen and Made in Sweden. They have no CE mark so they are older than 1984. Made in Sweden, not bad for 10€.
Treated with plastic restorer to the left, just cleaned with soap and water on right.
There's some rust, I put linseed oil on it... I figure that's good enough for now. Possible to do a better job later, separate the glass from the body with a thinner bath.
Plastic restorer on both
Tried applying some yellow headlight film, first time ever so I did a lot of mistakes, apparently you can use heat to make it go easier. Will do that on the next one. I like the yellow shine, will see though how I proceed, good thing is I can just remove it for a clear look.
I am cooking up my own circuit to make the lamps run on different voltages, so I can run the things as front position lights during the day, and when I need the fog lights (was real foggy recently) I can just press the fog-light button and they glow full strength. Also need them to shut off when the low beams are on and fog light switch is not depressed. I'll need three relays to make that logic work.
That's my theory - so while a mate of mine is designing/building the bestest possible version . . . I've been driving and enjoying the old fashioned, more original, version for the last 20 yrsand they are made to live inside a cars engine compartment, no need to invent my own solutions that just add complexity.
That would explain the broken teeth.Er, I don't think those are custard doughnuts.
