Nomad
- North Devon (for how long?)
Hi everyone, I have 2 related issues at my lockup :
1. The felt roof is leaking. Any advice or volunteers (in South East Wales) ?
When I got the garage a couple of years ago I fitted some extra battens as a temporary fix to stop the damp OBD from sagging and it's helped the water runoff. Before winter gets here I'd like 1 waterloged joist replaced, then renew the damaged OSB & refelt at least 50% of the roof properly. I'm capable of DIY but have limited tools and will struggle with full size OSB sheets, also I've no experience replacing felt. Help & advice appreciated ! @roofman
2. The lockup has a solar charger on the wall outside charging a 12v car battery in the garage.
Now I'm looking for something to automatically turn on a 12v fan for ventilation - any suggestions?
It's used as semi-long term storage for a car (often parked up for several months at a time when I'm working away), the car battery gets taken off the car when it's parked up and gets connected to the solar panel / charger fitted on the garage wall outside.
There's no mains power in the garage.
The garage has a damp problem and I'm wondering if I can connect a 12 volt fan to the car battery with an automatic on/off control?
Something like :
Sun is out - battery is fully charged - fan turns on to circulate the air in the garage / reduce the damp.
Battery level drops to 50% - fan turns off (with enough power in the battery to start the car when I need it)
Repeat ...
Hopefully this would cut down the damp in the garage and also keeps the battery healthy as it's cycling not standing at full charge all the time.
Anything I fit has to be zero maintenance as I'll not be there to monitor it and should have very low current draw when off so it doesn't flatten the battery in the dark winter months.
For the fan, I'm thinking a small 12v car radiator fan (edit: or low power 12v USB fan) would be the cheapest easiest choice?
Does anybody have any advice or suggestions ?
A ready made black box from Amazon/eb@y is one possibility or I can look at making something myself but don't know where to start (a bought kit of parts would help)
Photo just because ...
Something like :
Repeat ...
