CompoSimmonite
What is the source of paraffin ? Is it in a sealed 5ltr container or is it from a bulk tank. If from a bulk tank they have you considered it might be contaminated ?
What is the meaning of 35sec and 28sec please explain.You don't have to add much of it...
The reality is that youre just dealing with fractions of crude. Your bitchumen wouldn't do well in your weed burner, your 35sec diesel isn't great, your 28sec kerosene is ok, but you want more...
If you add a bit of a higher fraction then you'll probably get the results you want. It would be hard to see how you could move up the fraction scale without, well, adding a higher fraction. But you don't want to do that.
Again you probably don't need to add much.
Viscosity.
The "sec" bit is actually seconds. It comes from how long a known quantity takes to empty from a cup with a known diameter hole in it, at a known temperature.
But, in layman's terms, the lower the number, the thinner the mix.
...but it's not all about viscosity either. People add petrol to diesel in the winter to alter the gell point, but the more petrol you add, the lower the, umm, octane (?) of the mix, so, whilst it's thinner, per ltr, there's less energy.
Experimentation on your behalf is probably required! : )
A valve is opened slightly to allow a 'mist' spray of fuel under pressure. The higher the pumped pressure, the fiercer the flame. NOT exceeding safety pressure.
Sometimes being pedantic can reveal helpful details. Detail is good.Not sure if it's me being a bit pedantic, but that's not how it should work: The paraffin should be completely vaporised in the coil before it get to the nozzle, so that only gas comes out - no liquid or mist. To get to this state the coil needs to be hot, so there is usually a wick that gets soaked with fuel (by opening the valve briefly) and lit *before* the valve from the tank is opened for real, once the coil has had a chance to get good and hot. If you open the valve too early you'll get a big, sooty flame that will not be very hot.
Thank you for posting the photos. Also the description of what is happening in each situation.@mart
Weed burner fun?
Is it a pressurized one?
A few good tips.
Make sure the pre heat is good.
Never fill over 2/3.
Keep the pressure up to the range the manufacture say.
Get it right you get a flame like this.
Hot flame, but over filled.
Bad pre heat.
Wrong pressure.
Uncontrolled flame.
Cold flame.
Switch off and start again.
This is when you get everything wrong.
When you say only fill 2/3 is that to allow for the compressed air that will be pumped in after fueling up?
Do not uses paraffin as pre heat.I do wonder if the warming up of the coil is enough based on the limited amount of paraffin that the wick can hold/absorb?
It is for me.Is paraffin (or kerosene) that much cheaper than propane ?
Thank you. I didn't know that, excellent advice.Do not uses paraffin as pre heat.
Use "Meths." It will give more heat and the coil will heat up correctly.
Some manufactures will specify how much to use.
Best advice I can give is.
Dribble the "Meths." onto a good wick slowly. Until you see Meths dribbling from the end.
Then light, you will see the surplus being burnt off.
Here to help and pass on what I found out.Thank you. I didn't know that, excellent advice.
According to this site not me, Paraffin and Kerosene are the same thing. Worth a read, lots of info.I expect it is a nozzle problem and this is causing poor atomisation of the fuel at the jet. It is liquid up to that point but must be hot.
If the fuel is a) not hot enough it will not burn with a short flame - meaning the coil will not be heated sufficiently and b) if the jet is not the correct size and clean, the fuel will not be atomised properly, so will not burn until too far past the heating coil.
Have you never seen/used/owned a ‘Tilley‘ lamp or blowlamp? Plenty of videos on them. But be aware that some on youtube are real muppets when it comes to working them properly.
There is, of course, more than one grade of ‘paraffin’. It could be kerosene. It could also contain the longer chain hydrocarbons from the naptha fraction (from which petrol is derived). Petrol includes shorter chain length hydrocarbons which are likely to boil in the heating coil - and could be dangerous.
I might be blending kerosene (or your paraffin) with lamp oil (which will have more of the shorter-chain hydrocarbons present in the mix.
Service your weed eater to manufacturers instructions is your first action, I suggest. Then maybe get a better fuel for it.
