steveo3002
And then temper it.Spring steel, anneal it, bend to shape, then heat it and quench it, I think.
are these all things i do at home ,got a blow torch but dont have a blacksmith shopAnd then temper it.
thanks should be able to match something up near enough thereThey are called edge retaining clips, I doubt if they are worth trying to make if you value your time.
Edge Clips (including 'D' and 'S' types and Edge Panel Clips) | Classic Car Parts
Bresco fasteners fittings for classic vintage and veteran cars Austin Morris MG Rover Triumph Jaguar Ford Lotus Vauxhall Rootes Sunbeam Rolls Royce Aston Martin Fiat Daimler Reliant Riley Talbot Bentley Hillman Singer Humber Standard Lanchester Alvis BMW Mercedes VWwww.bresco.com
Use a piece of banding wire, bend to shape, drill holes through then use a self tapping screw. I've made several for use on scooter plastics.Lost a mudflap clip that are no longer sold...it's stiff springy steel , I'm capable of cutting one out but how do I make it springy?
Thanks for the explanation- I've wondered about that myselfAs said anneal spring steel strip, bend to shape, (May need to be done hot). Harden by heating to red heat & quenching, then clean till shiny & temper by heating till blue & quench again, You may need to have several goes.
I made a tapered V spring for an antique revolver a few years ago, took three goes before i got it right!
