We are actually disadvantaged as our stupid meters dont communicate so cant use fancy tarrifs through the night!I must be one of the lucky ones with a BEV. Or perhaps just ‘sensible’?
I charge my car on E7 power, almost totally. 7 hours each night @ 19p/kWh currently. That means I can charge approx 49kWh each night, should I need to. That is currently indicated as close to 180 miles on the GOM. I achieve rather more than 2 miles/kW! I often just charge for 1 1/2 hours, giving a charge of about 10 1/2kWh (near to 40 miles at this time of the year). This takes advantage of any solar gain from my limited PV at that time of day , effectively reducing my unit costs.
A source of this table would be good? I expect it is not particularly from a pro EV report - exactly the opposite, I would suggest.
If I were to reduce the E-7 hours, I can use power at a cheaper rate by immediately joining the Octopus Go tariff @ the current rate of 9.5p/kWh. I could, if I spent another grand, charge with power @ 7.5p/kWh.
That chart indicates to me the typical cost of the price-capped cost of electricity @ 4 miles/kWh.
I have used public chargers on just three occasions over the last 4 months, or so (4300 miles travelled). I also charged overnight at one establishment (I could have saved buying 20kWh @ 75p/kWh) I paid for that charge at a higher rate than my E-7, but considerably less than a public charger.
That public charging accounts for about 115kWh of the (less than) 1130kWh used - costing me less than £300 for my total charging costs.
That means my costs per mile have been around 7p/mile.
On the Octopus Go tariff, I could have nearly halved that cost (but with increased domestic costs, at this present time). I will be reducing my costs in the near future as I am monitoring my particular electricity use with a target of minimising my cost (not usage) to the minimum.
Some owners, who cannot charge at home might pay out at the indicated rates on that table, but anyone with brain cells to rub together would not pay the 20p rate. Those figures are real carp for all but the most stupid owners out there!
Don't belittle the UK too much. Still the World's 5th biggest economy.Using these Coal Fired Piwer Stations..... well they need so much Energy to run the Factories..... that are making all the Renewables....
To sell to us!
It puts perspective on (& makes a mockery of) our inflated ideas of being a global influence for environmental responsibility.
The UK is no longer a World Leader with an Empire & an influence.... we are a Customer for the goods others manufacture.
I know it is Fizzy. I know the UK has a lot of brilliant people also.Don't belittle the UK too much. Still the World's 5th biggest economy.
And most of the leading Fusion research is being done in Oxford.
I know.I know it is Fizzy. I know the UK has a lot of brilliant people also.
A pity that none of them work for the proper Administration of the country![]()
I don't think they ever have - certainly not in my lifetime, and remembering my Father & Grandfathers criticism of various administrations, not in their lifetimes either. You just have to make the best of what you have.I know it is Fizzy. I know the UK has a lot of brilliant people also.
25yrs ago I designed, helped build, commision an enormous two story machine for processing their big up to V16 engine blocks - spent a year in Germany, through a wonderful summer. Good memories!MTU the huge German diesel engine maker. MTU bought up a load of British engine manufacturers like Ruston, Paxman, Lister Blackstone etc. Nice to see it come full circle![]()
That must have been a sight to see!25yrs ago I designed, helped build, commision an enormous two story machine for processing their big up to V16 engine blocks - spent a year in Germany, through a wonderful summer. Good memories!
You can ask your supplier to change the meter to one that does if you are seeking such a thing . Ours was changed FOC when we moved from SWALEC to EON 15 yrs ago , had a new one a few months ago as part of the local area uplift .We are actually disadvantaged as our stupid meters dont communicate so cant use fancy tarrifs through the night!
Ours are fairly new and able to communicate, but it doesn't connect with the network as there is no signal.You can ask your supplier to change the meter to one that does if you are seeking such a thing . Ours was changed FOC when we moved from SWALEC to EON 15 yrs ago , had a new one a few months ago as part of the local area uplift .
ours wont connect to the display thingOurs are fairly new and able to communicate, but it doesn't connect with the network as there is no signal.
I think you have to plug them in and turn the power socket on.
The superchargers were 43p/kw today so at “about” 4 miles/kW that would be 11p/mile or £11 per 100 miles. So you are not far off (particularly as i imagine it does closer to 5miles/kw). My home rate is (i think!) 30p /kW so that would be more like £7.50 per 100 miles. Might also be worth considering servicing… i am coming up to 15k miles and 2 years ownership and servicing so far is £0.@atomant48 do you have a rough idea of the cost per 100 miles...I'm calculating that the MG4 will cost around £20 to charge and that will give 270 miles....have I got this totally wrong?
My use will be mostly city miles...from what I've read it'll generally do a lot more miles for this use?
Cheers...good to have a sense checkThe superchargers were 43p/kw today so at “about” 4 miles/kW that would be 11p/mile or £11 per 100 miles
That does sound good. If you are only doing short journeys then charging at home becomes easy and i honestly wouldn’t go to the expense of a 30A charger until youve tried on a standard plug for a while. Particularly as the incentives seem to have stopped. Unless you have one of those short window cheap tariffs (4 hour window i think) where you would want to maximise the current draw.Cheers...good to have a sense check.
For what I need the MG4 is a good fit I think...they're doing a 0% deal over 2 years which I like because it gives me the (put) option to hand it back if someone suddenly invents a 1,000 battery the size of a shoe box that charges in 10 seconds in the next 2 years!
