This tig thing just isnt how it looks on you tube ,,, could some one local have a go at welding with the gas you have ,,, just the same option only the other way round .I will do tomorrow, though i'm not quite convinced a test on steel will prove the gas is pure enough for aluminium?
I'm in Southport, Merseyside. I'm pretty sure it is a gas issue at this point, I'm just going to get another cylinder from another supplier to prove it before complaining to my current one, I was planning on keeping spare gas on hand anyway once i start doing actual TIG work.
Stainless steel gas shielding is the real test, aluminium doesn't need amazing shielding. But bright freshly ground steel is ok too for this purpose. What we're trying to prove at this point is that everything stays shiny bright and makes pretty colours, therefore the gas isn't the issue.I will do tomorrow, though i'm not quite convinced a test on steel will prove the gas is pure enough for aluminium?
just a lot of folk expect tig to be like it is in the videos , and it isnt , well not for a while , I dont know what your end goal is but before its a business allow plenty of time ,,,Not sure i'm following what you are saying with youtube? I'm not expecting to instantly lay down some x-ray grade weld worthy of a nuclear power station, but i can instantly tell something isn't right and i've experimented with so many different options at this point that i'm 99.9% sure that the problem isn't me or the torch setup.
You'd be surprised how common it is for a torch or gas feed line to be the issue. Especially straight out of the box.Not sure i'm following what you are saying with youtube? I'm not expecting to instantly lay down some x-ray grade weld worthy of a nuclear power station, but i can instantly tell something isn't right and i've experimented with so many different options at this point that i'm 99.9% sure that the problem isn't me or the torch setup.
fault finding anything is tricky if you dont have enough bits to be able to swap stuff about.You'd be surprised how common it is for a torch or gas feed line to be the issue. Especially straight out of the box.
Alls we sayin is, buying a new bottle of gas is quite expensive when you haven't ruled everything else out first. But then again, at least you would rule it out...
20A DCLets rule out gas. Switch to DC. Sharpen a tungsten, set 20 amps, get a bit of shiny bright clean steel and arc up for a few seconds on it. Take pics of the metal and of the tungsten.
Those both look worse than mine (and that's saying something...) Really looks like a shielding problem to me, that stainless bead should be bright and shiny, not grey and matt. 85A DC - so about 2mm stainless? The puddle on mild steel shouldn't have black smuts either (though 20A is very low!) - did you get given a bottle of Argon/CO2 instead of pure Argon (Argoshield Vs Pureshield)?20A DC
Also ran a bead on 316 stainless with 316 filler, 85A DC
I don't think the current's a problem - too litte can be, as you spend longer putting heat into the work, but going bit hot's not sucha problem.I did 20A because thats what Munkul asked for, the stainless was is about 1.5 - 2mm i just guestimated at 85A but yes its probably a tad much
why not try same test with tig and 5 , to see if the results are the sameI did 20A because thats what Munkul asked for, the stainless was is about 1.5 - 2mm i just guestimated at 85A but yes its probably a tad much... The cylinder says its pure argon, what they filled it with i don't know... though i am tempted to run some mig welds off it to see how it compares to my 5% mix.
Yep, i've pressure tested the whole torch and covered the whole thing in leak detector and theres not even a hint of a leakNot sure if its been mentioned yet... Have you got an o ring on the torch backcap?
