I use these and a sliding 'T' bar (plus extension if required) for hand tapping, great for restricted access which most of my jobs are.
Sounds like something i need to try on some scrap…. And probably with an old tap or 2!
I still have the tap wrench I made as an apprentice at college, in 1976. It works perfectly.A decent tap wrench of the right size.
There's not a great deal to go wrong with two bars, a notch in each, couple of tapped and a couple of clear holes, couple of screws . .I still have the tap wrench I made as an apprentice at college, in 1976. It works perfectly.
Still got mine somewhere, think it was made of hex bar.I still have the tap wrench I made as an apprentice at college, in 1976. It works perfectly.
Mine was round bar, but then we had to hacksaw and file finish it, cut the middle out etc, all by hand. A learning experience, along hand making with a mic stand, G clamp etc.Still got mine somewhere, think it was made of hex bar.
I'd just point out that mild steel is, in my experience, the most variable of all types of metal! Responsible for most of my broken lathe inserts and taps. One area cuts fine followed by a hard spot. That seems to be only round bar, plate and sq tube have not given me any issues.That is probably the worst combination to learn upon. Unknown material and worn out tooling.
When you start welding, you are never going to produce good beads on rusty bed iron using coat hangers as filler. Once you have a few years under your belt, you will then have the knowledge to make a fair go of it.
Do yourself a favour and use a piece of known mild steel, a new tapping drill of the correct size and a new, good quality tap. Once you have experience of the good stuff, you will know where, how many and the consequences of any liberties that can be taken with materials, tools and technique.
