madkayaker
Pro sparkey Pro Welder
the only way to meet "competent" for part P is to be registered with a part P body its a pain in the **** but that the world we live in
try wiring your own extension and then get building controll to pass the whole job off and they wontThe only way for completing work to a competent standard as a business is to be registered...
You are still free to undertake work in your own home yourself as long as you work to the required specs...
outside power .kitchens . and bathrooms other than that u can conect to existing circuits but if u arent getting anything done with building controll sticking there nose in just do it yourself as long as the jobs up 2 the mark . even if u sell your house they dont generaly want to see any paperwork on the wiring as long as it looks new ish and now hips has gone the journey its a free handyou may do a certain (very) limited amount of work, but not in a "special location"... ie anywhere where there is water or outside
(just a concern about the mismatch in rating between the 15A socket and the 16A fuse? Should I be using a 32A socket?)
or do u mean an rccd main switch in cuan rccbo is a residual current circuit device with built in mcb in laymans terms an earth leakage tripswitch with built in fuse. either 6 amp 16 amp 20 amp 30 amp ector do u mean an rccd main switch in cu
use either a 22mm conduit through metal box or a square 3x3 metal box put the gland on and take the 3 cores strait through into plastic consumer unit. metal box wants an earth link putting in and keep box close up 2 the fuseboard with none of the inner cores showingMorning all,
So I've been looking at what I need to buy and I think I've found the components I need to do the job.
Garage Consumer Unit:
http://www.screwfix.com/prods/33248/Electrical-Supplies/Consumer-Units/MK-Consumer-Units/MK-IP65-Garage-Unit
The 32A MCB for the existing fuse box:
http://www.tlc-direct.co.uk/Products/WYB32.html
So once I've got my SWA and a few glands and metal boxes I think I can get on with getting it installed.
I think I read somewhere that you can terminate the SWA into a metal box but bring the cores through the box and into your CU. Does this sound feasible?
Cheers
Luke![]()
