Screwdriver
Strangely whilst that pic does show it. It would make more sense to me to have a pic with the table direction altering and the cutter always rotating clockwise as that what going to happen in the real world.
I think this one will help me more.![]()
It's really not that complicated an issue but drawing arrows on the table is not going to help one bit. Certainly the cutter will most likely stay constant in its direction, typically clockwise as viewed from above but that does not tell you which direction the table "has" to go to avoid a climb cut.
You might be milling along the front edge of the workpiece, or the rear, that changes the direction of the cut relative to the table. Same goes for the left and right edges when the table traverses forwards or back.
I really can't see where the difficulty is. If you are moving the workpiece in the same direction as the cutter would like to drive it, it's a climb cut.
