ArcticWelder
New Member
- Germany
Hi there,Did you check dc link voltage?
You need to remove the coating before measuring. Otherwise you can get a bad termination.
Nope - as written in the first post the device doesn't show any signs of life when I plug it in. I can measure the voltage after the main switch and a little bit further down where the Varistor and this "big" - guess it's a filter - coil sit's.
I realized a -+15V supply already - working on the 5V now. Probably just using an USB charger... We are very limited up here...
Greetings
