Bobupndown
What could possibly go wrong?
- Northern Ireland
My wife rang me yesterday morning to tell me her car was 'sick' and making a rattling noise. I was in work and couldn't come to her assistance and she was about 30 miles from home. She had already driven it from home, and the previous day as well like this, unbeknown to me so decided she was just going to drive it home. She didn't get 1/4 mile before it cut out and wouldn't re start and then told me that it was leaking oil from underneath. I'd only changed the oil last weekend and had a horrible thought, had the oil drain plug come out and dumped the oil wrecking the engine? But I knew I'd tightened properly, I'm always cautious of this. So she rang RAC, busy as usual, we'll get to you ASAP etc. Finally a local garage breakdown truck arrived after a few hours. He took the engine cover off, confirmed that it was diesel, not oil leaking from no.3 injector. He couldn't get it started and said he could hear it was down on compression and "needed recovering". My wife paid £115 extra to have it dropped off back at home. I was expecting the worst at 10 years old and 172000 miles but had a quick look last night. Pulled the acoustic cover and looked at the injectors and sure enough no.3 was wet with diesel pooled all around it. Literally 30 seconds later I found that the bolt which clamps each pair of injectors was loose and you could wiggle that injector by hand. So tighten it back down and attempted to start it but it was obviously air locked. Some googling revealed that these common rail tdi's need to be primed using vcds software to run the fuel pump. Fortunately my brother has this so borrowed it and primed it several times but still refused to start. Ended up slackening off each injector feed while performing another prime. As soon as I had diesel at each injector it burst into life. So easy fix and all seems good again. Pretty disappointed that RAC's subcontracted recovery firm didn't diagnose this and be able to fix it at the roadside.
So long story to basically say, if you have a Tdi engined VW group vehicle, check to ensure these bolts are not loose. This one had obviously worked loose by vibration because until today the injectors in this car have never seen a spanner.
