Plasticine dam around the scablooks impressive , shame its not so easy to dunk a wing or door with a scab in the middle
unless we club together and fill a paddling pool with it
ER inside
I've used phosphoric acid and citric acid. Phosphoric is cheaper, more powerful, and lasts longer than citric acid, which seems to loose all its strength if left unused. Phosphoric acid does leave a coating, though that can be an advantage as it stops the parts flash rusting. If I'm zinc plating then the pickle will remove the coating, if I'm painting then I don't normally use acid, I just media blast.I have used citric and Evaporust.
My choice is now ER
Citric is cheaper but if you forget parts in there it will eat them, especially cast iron.
Evaporust just works really well for ages as a solution.
Another trick with it is heavy duty rubble sack.
Part inside sack with some ER solution.
Place sack in a large bucket /container and fill container with water.
That way you don’t need a huge tub and litres of evaporust to get a result, just enough active fluid to do the job and water compressed it around the part in the bag
I use citric acid but never looked into ratios. Any suggestion on a good ratio to use? I have some car parts to derust over the next few weeks.I've never used Evapo Rust but use citric regularly. It comes as a white powder, you can buy it in small amounts on the High St at Wilco's, but it's usually cheaper to buy larger amounts probably off ebay.
Citric will work out a lot cheaper, but may not be as good. An interesting approach might be to put badly rusted stuff in citric first and let that do the donkey work. In cases where citric does not do an adequate job, bring out the Evapo-Rust and see if that provides the final push. Interesting. I'll take a look at the Evapo-Rust SDS again and remind myself what that discloses in terms of constituents. Generally, I've never had a problem with the small extent to which citric will attack ferrous metal as distinct from dissolving rust. It's a very weak acid.
You can make a citirc acid paste with wall paper paste, apply and cover with cling film so it doesn't dry out.looks impressive , shame its not so easy to dunk a wing or door with a scab in the middle
I use this cup to a kettle of of water, probably overkill but it's just what I use to be consistent.I use citric acid but never looked into ratios. Any suggestion on a good ratio to use? I have some car parts to derust over the next few weeks.
Was that citric or evaporust?This is that rusty bracket left overnight. All rust gone when I wash it, it will be clean metal ready for etch primer.
View attachment 406482View attachment 406483
The stuff treated with it also doesn't seem to flash rust too quick. I know when I have used electrolysis etc it rusts before your eyes afterwards! That spanner has sat out since for more than 24hrs and not a single dot of flash rust. I'll treat it with the tool wax when it turns up in post.
Evaporust I am the OP who is testing it out for the first timeWas that citric or evaporust?
So when the part is removed from evaporust, what further work needs to be done.I had time to remove this bracket from the drink tonight after 48 hrs and etch primed it.
The rust removal is impressive, the light factory paint came off too
View attachment 406616View attachment 406617
After years of car restoration I wish I had discovered this stuff sooner
Are there any risks to the user, the contents or the cleaner unit using a Citric Solution in it?
I do similar (pyrex dish) now to save carb cleaner - good idea that to do same with CitricIt has been done (both heat and agitation) and reported successful. In the long term, I would be concerned about the effect of the acid on the stainless of the USC, but you could mitigate that and save on acid solution by putting the pieces and acid in a ziplock bag surrounding with hot water.
