Yeah, "That" was a poor example. I searched for something in a hurry, but I mean the ones which start as a one-piece casting. Proper, old British stuff with 1/2" thick tool rests etc. Rather than the modern (mostly far eastern) flimsy rubbish.
Two main ways:Any of them. How do you get 2 non existent phases from fresh air? This is electronics and my HND was 40 years ago. Trying to decipher it all.
When did that ever matter?It seems a lot of effort to run one grinder.
When did that ever matter?![]()
It seems a lot of effort to run one grinder, must be a pretty special machine.
Personally I would go motor swap route but if it's an integral part of the machine (as in bench grinders etc) not worth the hassle.
My 230V 8” Wolf grinder has been very good.Any suggestions?![]()
The traditional "rotary" converter is basically just a Static Converter with a Pilot Motor (which smooths things out & means you don't have a minimum motor load & the need to switch settings for different motor sizes ike you do with a base Static).OK, I spent a couple of hours reading last night and I think it’s getting clearer, but the issue is I have no clue how these converters work. I have a solid understanding of how electro-magnetism works (always did) but I can’t see where the converter “makes” the extra phases from.
I keep thinking back to my physics lecturer endlessly repeating how you can’t get something from nothing! So I think I’ve identified the missing knowledge, ie, how these converters work. Cos they clearly do work.
I like faffing with motors. Plug and play is boring.The other point is that 3-phase kit is generally quite cheap, so the additional cost of a vfd gives you a solid, capable machine. If you have to faff with the motor, so what? Isn't that what we're all about?![]()
A forum member claims just that. Or, in fact that you can create 3 phases using a cleverly wound transfomer.I think the Static uses the single phase to feed a double-winding transformer - so the voltage induced into the transformer creates the 2nd phase.
I think I remember that thread - my natural scepticism faded into outright disbelief pretty quickly - as you say, defies theory and he'd never either explain how it worked nor show a diagram...A forum member claims just that. Or, in fact that you can create 3 phases using a cleverly wound transfomer.
It defies transformer theory if so.
I must have missed that thread.I think I remember that thread - my natural scepticism faded into outright disbelief pretty quickly - as you say, defies theory and he'd never either explain how it worked nor show a diagram...
Dave H. (the other one)
Here is that thread:A forum member claims just that. Or, in fact that you can create 3 phases using a cleverly wound transfomer.
It defies transformer theory, if so.
I used to deal with Transwave (Power Capacitors) & while I don't pretend to understand exactly how they work, the principle I explained (& the principle components) are what you'll find inside a static (& a rotary) converter.A forum member claims just that. Or, in fact that you can create 3 phases using a cleverly wound transfomer.
