Having a few days off before starting the new job next week so I've managed to do a bit.
Picked up a "whetstone grinder" from Machine Mart last week for sharpening my wood turning chisels and it's now sat on a pedestal. The next task is to attack the block in front of the grinding wheel with a router and set the "T" track into it then make an adjustable bracket so the gouges will be ground at the right angle. (I briefly contemplated buying a Wolverine grinding job but my Yorkshire-ness objected to parting with the thick end of £200...)
An unused length of 1" thick pine board has been repurposed to hold chucks and faceplates and other lathe sundries:
And a similarly unused length of 40mm (proper measurements are available as opposed to this modern metric foreign nonsense which will never catch on) drain pipe makes a great place to store turning chisels. And there's plenty of room for the inevitable future purchases
A woodturner friend has the Tormek sharpening system for his chisels & every thing you need is an 'extra'. You need to sharpen a skew chisel? The jig for that is an extra. A plane blade jig an extra & so on.
He's now starting to use carbide insert tooling, no sharpening needed & great for abrasive hardwoods that quickly blunt normal chisels.
I've got **** every where pushed aside as haven't had time to get it all cleared, just saying, might be worth a look
no badge of honour , just cant get time at the moment , but do know where everything is , every time I make a major tidy up cant find anything afterwards..
