Mick Annick
- Burgundy, France (450 miles SE of Somerset)
perspective has made it look larger.
I'm very impressed there is some seriously nice wood work going on there . to cabinet making standard I should think and hand done too !This is most definitely not finished, but a major landmark was achieved today in a project I've been working on since late January:
Rear view:
It's going to be a tool chest to take on (self-catering cottage type) holiday with me, with the intention that it can also be used as a workbench (hence the thick construction, the stainless steel planing stops on the top and the slats on the back for stuff to be clamped to). When it's finished, there will hopefully be six drawers for tools (5 on the left, one on the right at the top) and an area in the bottom-right for a couple of small planes. All being well, it'll hold everything (give or take some bulky but robust stuff like clamps and glue bottles) for making small boxes and that sort of thing.
As a bit of explanation, my other half has M.E. and often needs some resting time during our holidays and I'd go stir crazy just sitting and reading, so it's nice to have some hobby stuff with me to pass the time while she's resting. Taking a metalworking lathe on holiday isn't really practical, but a bit of hand-tool wood bothering is.
The chest base has been by far the most significant (mostly) hand tool woodworking project I've ever done (and probably the most ambitious project of any kind I've ever done). The only power tool usage on the project so far has been using a bandsaw for one specific type of cut (resawing thick boards into thinner ones). Everything else has been hand tools only.
To give you an idea of why I think this is the most ambitious project I've done, this was:
That's quite a lot of firsts in my opinion!
- The first project in which I've made panels from rough-sawn wood entirely by hand.
- The first project where I've cut dovetails without any sort of saw guide.
- The first project in which I've cut housing joints (for the middle upright support and drawer runners).
- The first project in which I've cut wedged through mortice and tenon joints (or any entirely hand-cut mortice and tenon joints for that matter).
- The first project in which I've cut half-lap joints (for the brace on the back that is intended to prevent racking while planing on the top surface).
- The first project in which I've used protein-based glue (fish glue in this case).
- The first project where I've had to come up with my own way of dealing with wood movement. On previous projects I've just used well-known techniques (buttons for table tops, grooves for box bases), whereas making what is essentially a five sided box where all sides needed to be rigid took a bit more thought.
I've never made wooden drawers before (unless you count pocket-hole jointed plywood carcases with ball-bearing drawer runners), so there are more firsts to come...
I could have shown you a complete-ish battery tray, it’s on my bench awaiting a repair. The baskets who made these vans never stopped rainwater running down under the bonnet, designed in failure...Today I made the camper van whole again.
I thought the battery tray would be the tricky bit but the DS lower inner guard was worse.
There was not much left for a pattern.
Forgot to take any photos during, but this is after a coat of white epoxy.
It's all a bit lumpy but it will do the job. I'll seam and underseal it after it gets its MOT.
Battery tray was similarly lacking in areas, so made my best guess.
I used 2mm steel but didn't have a bit big enough so I welded two off cuts together.
Mig was at my mates shed so I used tig and planishing it flat.
My good helmet was with the mig and the one I had was flashing on and off so that's my excuse, but it's functional.
I used my press and a form tool I had made up for something else to make the pressing for the bolt hole.
I was pleasantly suprised when it fitted.
Other side was similar but not as bad.
To be fair the outside looks pretty busy!Master of understatement.![]()
Having a few days off before starting the new job next week so I've managed to do a bit.
Picked up a "whetstone grinder" from Machine Mart last week for sharpening my wood turning chisels and it's now sat on a pedestal. The next task is to attack the block in front of the grinding wheel with a router and set the "T" track into it then make an adjustable bracket so the gouges will be ground at the right angle. (I briefly contemplated buying a Wolverine grinding job but my Yorkshire-ness objected to parting with the thick end of £200...)
An unused length of 1" thick pine board has been repurposed to hold chucks and faceplates and other lathe sundries:
And a similarly unused length of 40mm (proper measurements are available as opposed to this modern metric foreign nonsense which will never catch on) drain pipe makes a great place to store turning chisels. And there's plenty of room for the inevitable future purchases
I don't know weather you may be aware but a cleanup might be called forI was to be making a mast for a boat but I reckoned it was too big so I cut out some hardboard to let the skipper see and he agreed. So I scaled it down a bit and it seemed better although the radar plate looked a bit out of proportion but nothing can be done about that as he wants the open scanner type and the slightly smaller version would cost him £4k more.
Anyway got two sheets chopped on the plasma.
Tacked it up.
Then the wind started picking up so I had to weld it in my workshop which doesn't really have much room.
Still have loads of brackets etc to weld on but quite happy with todays progress.
That is it cleanI don't know weather you may be aware but a cleanup might be called forI've got **** every where pushed aside as haven't had time to get it all cleared, just saying, might be worth a look
Not many pikeys round your way? Lot of offcuts in your yard….That is it clean
I just don't have room to put things, workshop is the wrong shape oh and BTW that is the part of my workshop with the most room in it![]()
Bet you are getting really quick at doing those!Made 60 strawberry trollies 7 years ago,now due to regular punctures,farmers changing to solid tyres,so I’m putting suspension on each corner and widening them as he’s changed tray suppliers.View attachment 398626View attachment 398627View attachment 398629
