I'm exhausted just thinking about it please slow down if only for my sake.Your going to burn yourself out, grafting like that, and you can't rush these things.
I'd suggest putting the kettle on, having a brew and some biscuits, then maybe a couple of beers. Grafting all hours of the day and nights no good for anyone.![]()
Old saying:- You can always tell where a carpenter lives , because his gate hangs on one hinge .This sort of stuff is what I do for a day job so the house is like a bloody busman's holiday ! . There extenuating circumstances when we started doing the house we didn't have any sodding money !
No bath . use a shower with a below floor or inside the floor joist space trap is even better think our inhe floor trap is ji=ust under 90 mm top to bottom..... 10 mm below the floor tile edgesI'm always amazed when people tile in all the services and drains with no access available afterwards.
When I did our bathroom I made sure the water ans waste was accessible one way or another for a few years down the line if anything started weeping.
Same with baths when people fit the taps first because there will be no access when it's in final position. No tap is bullet proof..
Be prepared to be amazed then , the majority of the time access from here there and everywhere else just isn't option , and generally pipe work is filled and tested before it's closed in .
A right angle on a water draining pipe for the shower ...not something I'd ever do as you can't clean it of long hair & general soapy gunge . chamfered internal & externally solvent welded pipe rarely leak if done properly . Wrapping fibre insulation hair roll round the pipes where they go through the joists stop them vibrating and allow an easy slide .Since our shower was installed we have been plagued with a squeaking waste pipe whenever you get in it so when the builder pulled the kitchen ceiling down he opened out the slot in the joist to cure the problem
In one bungalow we had pressure to the bat was terrible . & even worse to a shower so I put in a power shower that emptied the loft header tank in short order . While I was at it I decided to put two stops in the supply in the wet room & added two small extra header tanks in the roof void set on a fraame sitting across the 3 foot wide hall way wallsThis also started with a mark on the ceiling last Wednesday. Turned out it was the mixer leaking in the wall.
No way of turning water off just to shower so put two isolation valves in reachable through the round speaker hole.
View attachment 398333 View attachment 398334
Well the biggest No No ! there to me is never ever use push fit waste on anything your never gonna get to . Solvent all the way for me .Since our shower was installed we have been plagued with a squeaking waste pipe whenever you get in it so when the builder pulled the kitchen ceiling down he opened out the slot in the joist to cure the problem
your a bit biasedWell the biggest No No ! there to me is never ever use push fit waste on anything your never gonna get to . Solvent all the way for me .
Different matter as far as I'm concerned Gaz , I've used 15mm and 22mm pushfits on copper and plastic pipe of all brands over many many years and only ever Had two failures , those were both on the old grey Hep de mountable fittings and as I've stated fecked on with by others and the grab rings inserted the wrong way . Which is why I think most manufacturers now make fitting you can't take apart ( to stop the idiots )
