Where abouts are you? I’d take it off your hands if you’re close. About time I got soemthing proper for the jobShame you aren't closer, I have one that I keep tripping over. They work, but they are a workout.
Bolting it down to something solid, or a pallet you can stand on is essential.
The bead breaker bit isn't the most robust, and you need to have a wheel which the centre post fits through (i.e. you can't do small mower tyres etc).
Be warned, if your alloys are nice, they won't be when you are finished. You can get a No-Mar bar for them (got one of those too), which sort of works but the clamping bit still marks the wheel.
If you just want to pull tyres of scrappy alloys or do steelies then that isn't much of a problem.
Also buy a tub of tyre lube and use it liberally!
ones with run flat tires can be savage , and that with the real tire shop machine .Some of the modern rims have a bead that makes even the proper bead breakers struggle.
Bob
I got one a few years ago and the blade that breaks the bead needs to be made bigger or it may slide too much and not break the bead, I also found that the tyre and wheel needs to be flat, I used some 4" x 2" pieces of wood around the base.I know it's been covered before but I have maybe 15 or more steel and alloy wheels I want to remove tyres from.
Largest wheel is 15 inch is this one any good.?
I've not got time to make or fab anything up.This one is £65 all in on evilbay.
They used to be built onto the walk around tyre changers?This one is up for grabs.
That’s a hellish handy tool. I might be coming down with Rick when he collects that gm 6.5, I’ll take a ganderThis one is up for grabs.
I wouldn’t bother, the one I’ve got looks similar and is pretty useless, it just slides down the tyre rather than getting right into the seam between tyre and rim and forcing the bead down the rim.I know it's been covered before but I have maybe 15 or more steel and alloy wheels I want to remove tyres from.
In the flatlands of Norfolk, where the men are men and the women are usually related.Where abouts are you? I’d take it off your hands if you’re close. About time I got soemthing proper for the job
