Do you have a big chest freezer ? If so put the suitcase in and after a while you'd be able to chip the glue off. Otherwise try dry ice
It's surprisingly effectiveWickes do a paint and varnish remover which I use for anything and everything. It's a gloopy white liquid, and it doesn't do anything very fast, but give it a little time and seems to be good at softening up a great many things. I've been using it for years.
It's not glue, it appears to be some sort of primer that was under the black paint. That was the final bit of the whole panel which was stripped with the Screwfix stripper.Is that yellow stuff glue? If so it looks like what I'm after. The blackening implies it's doing somthing other than just being a solvent which is what I need.
I tried this lot today.
Gun wash, ethanol, acetone and brake cleaner.
Best of the bunch was the gun wash and scrubbed with a scotch pad.
Still a slow job though cleaning up this soft top frame
View attachment 396813 View attachment 396811
Can it? I mean I'm now aware that it's generally a bad idea but joints?I hesitate to suggest it but I have often found that when all else fails , as a last resort, petrol can work well.
Be careful of it getting on your hands as it can affect the finger joints .
I only noticed it after the introduction of the unleaded petrol . I don't know if I was just allergic but I proved it several times to myself. Doesn't seem to have had any long term effects but with getting old it's difficult to tell.Can it? I mean I'm now aware that it's generally a bad idea but joints?
Used to wash every component in petrol before degreasers were a thing, spent many many hrs cleaning stuff in an old saucepan with an old paint brush. No disposable gloves either, they were still only in hospitals. Yet another horror to look forward to![]()
if its enviromentaly friendly and none caustic it will be crapThis stuff?
Wickes Paint & Varnish Stripper - 1L | Wickes.co.uk
Wickes Paint & Varnish Stripper - 1Lwww.wickes.co.uk
if its enviromentaly friendly and none caustic it will be crap![]()
I think that is what I recommended (packaging is very slightly different to my last bottle). Now, it is NOT methylene chloride, but I find it very good for lots of jobs, from stripping paint to cleaning off all kinds of non-specified crap. It's a viscous liquid so hangs in place when vertical. It may take 30 minutes or a few hours - just depends on the material, but it seems to be very, very safe, doesn't stink the place out and doesn't do bad stuff to skin. Generally, I've found it OK to use on plastics, but do check that out if critical.if its enviromentaly friendly and none caustic it will be crap![]()
I wrapped bits a time with a rag soaked in gun wash, then scraped and scrubbed with scotch pads. Worked on it most if the day and probably ended up with brain damage from the fumes.If it's no rush i use old towels with gun wash on and if i can wrap that in cling film its a bonus, it will remove glue and years of paint if you leave it a few days.
