its fine for being under the car and using on boltsMapp torch? Rothenburger?
That’s interesting. Did you build that?Google Ceramic chip Forge. Many schools had them and they turn up on eBay regularly.
Here is a picture of mine yesterday heating up a massive bit of my JCB 3CX that I wanted to straighten. Remarkably fast, and gets hot enough to do hammer welding, which I have done but years ago. I run mine on domestic 240 volt single phase and a 47 kg propane bottle.
It has the forge basin itself that gas & air is forced though to heat as in the pictures, but it also has a powerful propane and forced air hand held torch - the force air is from an inbuilt compressor.
To get our BBG starter going, I just put the heat gun into a hole in the lower bit, after the newspaper had died down. Gets them glowing pretty quick!How about a BBQ chimney starter. I've heated some thick stuff layed across the charcoals on mine. Takes about 30 mins to get up to temp though!
In that case I’d double check with the insurance wether they’ll let you use oxy propane.I do have TIG yes, it won't be something that gets used a great deal, and I would really only need to be bending to 90 occasionally more but mainly for brackets etc not really for forging as such.
We had one in my last school, the ceramic chips lasted a long time, I used it fairly regularly & used to change out damaged or contaminated chips as they became worn out. Schools like them because they are clean & not dusty like coke. Downside was not nearly so controlable as coke and tends to retain heat for a long time. They make seriously good toast! Ones we had were made by Flamefast who seem to have cornered the market for school forge & brazing equipment, they are fitted with a host of safety cut off valves etc for school H&S which may give problems & be expensive to fix.Always fancied one of those ceramic chip forges. How long do the chips last?
if your only doing thin brackets the rothernberg will do you the blow lamp comes with a cost thoughI do have TIG yes, it won't be something that gets used a great deal, and I would really only need to be bending to 90 occasionally more but mainly for brackets etc not really for forging as such.
I do have a rothenberberg torch that's runs off the yellow map gas (not sure if there's different ones etc) use it mainly at work for warming bolts up but never thought to try how hot it qould get steel to bend.if your only doing thin brackets the rothernberg will do you the blow lamp comes with a cost though
if your doing the size of rebar you want something better to heat and bend with a j tube rocket stove will do what you want but you will have to use firbrick with it otherwise it will destroy the metal box as it glows red white hot if you dont as stainless steel box section also does the same
if its only for casual bending its free and no cost extra and no fan needed
for a lot of rebar bending id suggest a forge is the better aproach
It will get hot enough to bend 12mm rebar easy.I do have a rothenberberg torch that's runs off the yellow map gas (not sure if there's different ones etc) use it mainly at work for warming bolts up but never thought to try how hot it qould get steel to bend.
