malcolm
& Clementine the Cat
- Bedford UK
I was given two chandeliers and I'm planning to put them both up in the main room downstairs with the high ceiling that I'm calling a ballroom. There will be 32 bulbs in total and I guess that on some occasions that might be a bit excessive. I'm thinking it will need a dimmer.
The room is also a corridor and it would be handy to flick a switch rather than fiddle with a dimmer switch to go through. Within the regs can you have a dimmer control on the feed separate from the switches?
Looks like dimmers are pulse width modulation there days so should save energy when turned down rather than burn a hole in the wall. Any recommendations for good ones that avoid flicker? My switches are all Click UK from Scolmore.
