GraemeVW
- Chesterfield
I have had a bit more of a play at welding aluminium.
My set up is not ideal, but I'm not really after changing any equipment.
I only ever have a small need to stick a couple of bits of aluminium together, which I can achieve, but it's not pretty. Once filed back it's done it's job though. But thought I'd see what I could do to improve things a bit.
It's a Clarke 150en turbo or whatever.
Teflon liner, can't remember if wire is 0.8 or 0.6. Using disposable pure argon.
I'm wire brushing with stainless steel brush before hand and pre heating a bit with map gas torch.
As I say, it does stick aluminium together but wondered if I could get a better result. The issues are...
I'm running the welder at about half power, it seems to need that. It's probably on about half wire speed too. But this gives a very raised weld. It seems to be about the only setting that works though. Turn wire speed down and it just burns back. Turn power down to match a lower wire speed and it just splitters and spits.
It's not the most controllable weld!
I'm reasonably ok at welding steel. I have a better welder for that though but I used to use this Clarke for steel.
It just feels like everything is happening too fast, but trying to turn stuff down just results in it not really working. There is one setting that works, ish, but is just a flurry of wire spark and splatter.
The weld is sooty after. Wire brushes straight off after, but didn't know if that's significant.
I'll be honest, I'm surprised this set up works AT ALL, so I'm happy I can at least melt bits of aluminium together, even if it does require alot of clean up after. I certainly wouldn't rely on it for strength though, but I have no need for that.
I know what folk are going to say, get a tig, or at least get a spool gun. But I really don't need to set up properly for welding aluminium. I just had this old Clarke left over after upgrading to an eland, and figured I'd see what's possible.
If this is as good as this set up gets, then so be it. But if I can tweak anything, or learn better technique, then great.
