How about my folding eklind Allan keys or 8mm combi spanner?Don't suppose my bolt croppers are up there too are they?![]()
Christ, I’d better get up there again tomorrow, too dark to be clambering up ladders tonightHow about my folding eklind Allan keys or 8mm combi spanner?
That has to be the best reply of the week.Don't suppose my bolt croppers are up there too are they?![]()
turn on subtitles and text translation if this feature is enabled.Typical I say I know nothing about Slovenia, and then go and back it up by completely misunderstanding the video you posted!
I have to say I admire your commitment to searching out history, sinayavina sounds horrendous now. God knows what it was like then…
Thank you Sergei.
Quite into doing these little signs at the moment.
Kinda a repro industrial feel.
A few minutes here and there, and an offcut of second rate timber.
Very nice job!!A small arbour (6mm dia) for a 3D touch probe.
Turned from 440C stainless - there was a lot of swarf to get rid of to find a 6mm diameter shaft inside a 45mm diameter bar.
Made some nice chips, but they were so hot, they melted through the plastic cover over the lathe bed!
Had to swiftly make a metal cover, as the chips were as hard as hell, and I didn't want them getting under the saddle if I could help it.
I found the material a bit touchy on feeds and speeds - if I got it wrong, it made some very pretty swarf (which, incidentally was horrible to deal with - stuck to everything and then broke into little lengths).
Got there in the end!
Managed to finish the other side with the shaft held in a collet, taking very light cuts.
I use special water soluable cutting oil as well with small glueing brushes. Dont use tin's anymore but plastic caps off spraying cans, with a strong magnet (from computer harddisks) in, keeps me from bumping them on the floor and collects the swarf in the fluid.As a hobbyist player I often use WD40 to give things a cooing spray every now & then , got a Shipman's fish paste jar with compressor oil in it attached to a bracket on the head stock body and a pigs hair artist brush in it for times when things need a drop of better oil cooling
Today & yesterday I made these bits (apart from the bearings and screws, unsurprisingly):
I then put them together to make this (the big one, with its little brother that I made from a kit a while ago):
I then tried it out and made this...
... 8 mm AF, 15 mm deep hexagonal hole in a bit of 16 mm stainless steel bar.
The design was very closely based on the one from the Hemingway Kit that I'd previously made. I basically just doubled most of the dimensions and then tweaked it for 12 mm silver steel broaches and to suit standard size bearings (as you can't get bearings in exactly double the size of the ones in the Hemingway kit).
The Hemingway kit one will do up to 6 mm AF and up to 7 mm deep, but I want to be able to cut a 14‑ish millimetre deep, 8 mm AF hole for an upcoming project and I thought it would be fun to see if I could scale up the Hemingway design.
Link not workingNot made today, but installed the railings I made last month. Back tomorrow to give a final coat of paint.
Nice piece of land you have there, what you now want is a flailmower.Fenced half the new paddock off and started hacking the savannah down with the strimmer. Its called “marsh field” on old maps and I can see why. I reckon i can hide a small turnip patch at the back without yard woman knowing
View attachment 394872 View attachment 394873 View attachment 394874
