Olderisbetter
- Wolverhampton
I have a GYS 30a 10 years old still does a great job but i rarely need to cut more than 2mm, no built in compressor but i have a decent sized one in the shed
i walked away from one of the expensive ones even i could buy for 100.00 for a 1500.00 machine as it was a high risk 2nd hand marketCheers. I need a machine with a built in compressor. The parkside/Lidl one would be perfect if it had that.
Any recommendations new or used? Looking to spend minimal.
Firstly, is second hand adviseable?
Secondly, what am I looking for when buying a plasma cutter? What's a good spec, must have features, and things to avoid?
Thirdly, I've seen a used Telwin Tecnica 34 going for a reasonable price. It has a built in compressor. Can't find much info online. Buy or avoid?
That looks like an older transformer machine.Hard to answer that, I bought a Murex tradecut 20s as spares or repairs for £100. Got it home and attacked the insides with an airline, it needed a new air regulator and that was about it. Been using that for about four years now with no issues. If it needed much more than that it would have gone in the scrap.
Bob
if it had needed more than that you also would have been out of pocket as well if it had of gone on the scrap pileHard to answer that, I bought a Murex tradecut 20s as spares or repairs for £100. Got it home and attacked the insides with an airline, it needed a new air regulator and that was about it. Been using that for about four years now with no issues. If it needed much more than that it would have gone in the scrap.
Bob
I've never used a machine with a built-in compressor - I struggle with the mechanics of a tiny compressor being able to adequately supply the compressed air needs of a plasma cutter. My current machine is the R-Tech P50HF. Had a Plasma Part Cut 50 Air Start before and a R-Tech 30 Amp before that. The Cut 50 seemed OK, until I tried cutting stainless. It was hopeless on 3mm plate unless the amperage was maxxed out. The R-Tech is in a whole different league. It eats 3 mm stainless at about 25 Amps.Firstly, is second hand adviseable?
Plasma cutters need lots of good quality, clean, oil-free, dry air. I seriously doubt that the built-in compressor models provide this. If the air quality isn't great, you'll eat consumables. I had piston compressors before - noisy, hot, low-efficiency and spewed oil. I blew a month's pay on a Hydrovane HV02 at the beginning of this year and haven't looked back.
I'd say you want a pilot arc/HF start machine, especially if you're going to cut less than pristine metals. Amperage will depend on what you envisage cutting. A quality torch with readily available consumables is a must. You'll get through a lot of nozzles and tips, especially in the beginning, so it's best to go with an industry standard torch that is replaceble and uses readily available consumables.
Yes, Hypertherm's Powermax 30 Air has one, but it's only 35% duty cycle at 30 Amps and I suspect that's mainly compressor limited...... It's a lot of dough for portability. It costs almost as much as my Hydrovane air compressor, which should be good for ~100,000 hours if serviced regularly.Some big name brands (including hypertherm) do plasmas with built-in compressors so they must be fairly confident in them...
