Same as me, I have all I want, just need time to enjoy it@Parm
Everybody I know aspires to a monster motorhome or a holiday home in Spain for retirement.
I really want greenhouse myself - following this thread with interest....?
I really am... (the simple life)....![]()
Greenhouse will be 5 star by the time I’ve finished with it
Thanks for your advice, but it’s staying where it is, it works perfectlywith it being a rear fence its would be worth turning and moving 3-6ft to the right
then you can build a block wall at the rear leaving 2ft at rear of it for access then insulate that wall
that mean one set of glass is no longer needed then you can go down a few routes from there
our greenhouses are set in line like these not like the southern facing ones
note the double doors and also the cover over in winter note this is canda winter
for other ideas for collecting water and other things
Council replace ours when cracked, they have a bit on the website where you can order a new one.Ah ha - your council uses the same bin supplier . . . and the same lifting support on the back of the bin lorry, part way up the bin, flexing the do-dar out of the bin . . . and it's still your fault when the bin splits and it's you who pays for the new one . . .
Look on Freecycle s for a damaged aluminium one about 8X 12 . snip off the glass retaining spring clips and simply break off by overtightening the aluminium bolts . Stack removed sheets of glass in tens with three or four sheets of old news papers between the sheets and put them on some decent thick flat ply .@Parm
You'll regret wood and the maintenance needed to make it last 12 years or more , that's why moved to aluminium over 30m years ago for the first one .I think I am gonna build one on the base of one of my old sheds - it is on a concrete pad - several rows of engineering bricks up to waist level - then build hard wood frame on top of it - then glaze it.
Nothing??! Good idea. Be keen to see it finishedHere's a mental idea I had...
I've stacks of old greenhouse glass, collected by the previous house owner. The ancient, already glazed, wooden greenhouse here is falling down and we're slowly getting rid of it.
I've recently gone and got one of my brother's cast off aluminium greenhouses as he's upgraded. It did have plastic panels but they're all knackered.
The obvious is to use the stack of glass to glaze the aluminium greenhouse but where's the fun in that?
So...3D print corner connectors and make a geodesic dome out of the stack of glass.
CT1 all the adjoing edges etc.
Should be self supporting right?
What could go wrong?
The end wall of my lean-to greenhouse does flex quite a lot in the high winds we've had over the last year or two, I've had to replace a couple of panes recently but they were held in place with the old-style mastic strip that's been in there for 30+ years. There is a single bracing piece across the wall, but I'm thinking of adding more - in one bout of "weather warning"-grade wind, I could see the wall flex and didn't want to stand near it. The lean-to covers the back door which is the main entry to the house, so I can't just not go in there when it's windy. I'm not sure whether making the frame stronger will make it worse or better in terms of glass loss.How non flexible is CT1? Reason I ask is that usually greenhouses have a bit of flex and the glass is held in with clips. Is that to allow for movement in the wind?
Really?that's why moved to aluminium over 30m years ago for the first one .
So the feds can’t see what herbs are being grownGreenhouses seem to be making a comeback around this way. People who you wouldn't think have any interest in gardening are putting them up. And interestingly they mostly have opaque glass/pvc.
Its good for the soul pottering in there with everything growing.
ALao factor in the rising costs and recent supermarket shortages of certain vegActually very true and proven. I think some GPs are prescribing "gardening".
Looks fine to me.....About 10 years ago I built a timber frame greenhouse, clad in plastic sheet and covered with a corrugated clear roof.
For the last 3 or 4 years it’s not been used and quite neglected and very heavily overgrown
With the chillies doing well it’s time to get it sorted and operational.
But first I needed to get to it
This is what I started with
Cleared up the patio section
Then found the pathway
I will clear the ivy and see what shape the greenhouse is in
