Does the roloc holder literally just screw into the cut off tool head, any link you got would be ideal.It's what I use, the lidl 12v cutoff tool, with a roloc holder from ebay.
The brushles ones are better, but lidl don't do one yet.
They are with a 75mm disc. 50mm have a lot more torque. Plus remember you are not trying to cut through a panelI have a lidl cut off tool which I use as intended cut off only. Its a little weak if I'm honest.
The M12 Milwaukee one I have is fantastic. Lots of power. I keep a storage try with all the attachments. It is invaluable for me restoring cars.
Any recommendations on what bit and cutting discs for the m12 die grinder?I have a lidl cut off tool which I use as intended cut off only. Its a little weak if I'm honest.
I’ve run rolls of the stuff…. Through both a normal transformer mig (the old sip ideal range being particularly well suited) and my kempii minarcmig evo200.
Standard rollers, standard liner, argon gas.
I wouldn’t use anything else for bodywork, it Really is superior.
Thats your problem. Flap disks can curve and cut both sides. Use a hard disk.
What has galvanised got to do with mig brazing?
SiFmig 968, 5kg, 0.8mmI fancy buying a couple of rolls to try out.... any recommendations on what to buy?
