prepman
- Gwynedd UK
Thanks...I doubt the screen wash had ethylene glycol in it...
Ethylene Glycol Antifreeze BAD....
Ethylene Glycol is a poison, 30ml can be fatal for an adult, 4-5ml can kill a dog and 1-2ml can kill a cat. It is sweet tasting, an Asian woman in the UK, has been procectuted for killing her husband by adding it to his curry!
0.5-1.0% in engine oil can cause failure to engine bearings. Automatic gearboxes fail when shared coolant radiators fail, allowing minor contamination of transmission fluids. Mercedes and VW dealerships are issued with test kits to find Ethylene Glycol in oils, to fight warranty claims. It also damages some of the new types of waterbased paintwork systems.
It stops water in engines freezing, it raises the boiling point of coolant and contains inhibiters to stop internal corrosion of engines.
It is classed as hazardous waste.
Propylene Glycol Antifreeze GOOD....
Propylene Glycol has one extra carbon atom in its chemical structure, but it has a very lower toxicity level. So low it is used in food, pharmaceuticals and cosmetics.
It freezes at the same temperature as the toxic alternative. It does not damage engine, gearbox bearings or waterbased paintwork.
It also stops water in engines freezing, it raises the boiling point of coolant and contains inhibiters to stop internal corrosion of engines.
The effects of poisoning Ethylene Glycol take 12-36 hours. Symptoms of Ethylene Glycol poisoning are in this order, central nervous system failure, changes in metabolic processes and kidney failure. The central nervous system is affected early in the course of poisoning and the affected indervidual may look drunk & intoxicated. One antidote for Ethylene Glycol poisoning is Ethanol (Ethyl Alcohol). Ethanol is a competitive inhibitor of ADH. Ethanol acts by competing with Ethylene Glycol for alcohol dehydrogenase. Doctors normally precribe pharmaceutical grade Ethanol by injection as a 5-10% solution with 5% dextrose in water, but it can be given orally in the form of a strong spirit such as whisky, vodka or gin. Alcohol dehydrogenase has about a 100 times greater affinity for Ethanol than for Ethylene Glycol; Ethanol therapy saturates the enzyme, inhibiting further ethylene glycol metabolism thus limiting the formation of toxic metabolites. The other method of treatment is Haemodialysis but you are going to need a specialist hospital for this.
Sorry about the loss of the dog!
It turns out that it wasn't the screenwash with an ethanol low concentration. What I later did suspect was an antifreeze container with very little in it, that had fallen over in little stone building with an open doorway. I saw him lapping something up in there when it is was torrential rain. Usually the old door is propped shut. I keep all my oils and solvents in there. None of which would be attractive to an animal. Except the antifreeze. So I've been mortified that I've killed my best friend of the last 9 years.
Being more dry-eyed and clear thinking I got the container and read back. Would Bitrex have stopped him? The vet thinks it was natural heart failure, but I wasn't so covinced. Just the shear energy he had prior. If it was another source of poisoning it raise sinister feelings.
PS The avatar is my previous seafaring dog...euthanised at 16yrs. Was rescued along with me by lifeboat crew one time. A saint of a dog. But my 1st and one before him was the dog from hell....and just to rub it in euthanised at 17yrs whilst trying to bite the vet.
. But no Benji.
