Need some advice from the collective on magnetic drills, it's not a must have for me as I have a 16 speed pedestal drill (but which has seen better days as it doesn't handle vibration well, bearings probably need replacing) but a Mag drill would come in handy as I am building an approx 8mx8m steel framed shed and is more portable than lagging around a pedestal drill back and forth from the site on a daily basis on the trailer, and once complete would come in handy afterwards for other projects requiring larger holes. I already have about 7 annular cutters which I could use, largest is 40mm.
Personally I think that the first one is better value and I am leaning towards it, but would really like the 1800W power of the second one, though not sure if I would ever use a drill bit larger than the 16mm because I would then use the annullar cutters.
Has anyone here bought any similar units, and what are your experiences with them?
Looking at some cheap Chinese made units on E-bay, both with some con's and pro's. Not necessarily from these buyers as there are heaps of sellers selling identical units.
1) https://www.ebay.com.au/itm/334760488055
Pro's: Comes complete with a drill chuck and a weldon adaptor, coolant bottle, 11 annular cutters and a few other bits and pieces
Con's: Only can drill to 16mm using twist drill, 1300W
2) https://www.ebay.com.au/itm/144967134116
Pros: 1800W, can use twist drills to 23mm due to lower speed, higher wattage and higher torque.
Cons: No coolant bottle, doesn't have a weldon adaptor, nor does it have the annular cutters, a bit slower RPM
