I made my own.
5m long 2x8" and paired up with 2x2 on the bottoms.
Supported in joist hangers at one end and resting/bolted/nailed to the top of the dividing wall at the other.
The 2x2s were glued and screwed every foot or less.
The end result was a ceiling with no sag and when I laid the floor upstairs there's no bounce at all. The addition of the 3/4" ply flooring made the whole thing rock solid.
View attachment 389394View attachment 389397View attachment 389400
Can't hang a crane trolley on wood......Just sayin'
And you did ask on a welding forum to boot.
these are lighter than the I wood joists
A couple of observations:
Selco only do free delivery for £100 + VAT minimum order.
I think it is 100% certain that the flanges of a 16' long commercial one will NOT be made of continuous lengths.
As above, commercial ones use finger joints, which maximise glue area. Axminster among many others sell the cutter:
Axcaliber Finger Joint Cutter
The extra gluing area produced by using this cutter makes for an incredibly strong edge to edge joint. With a maximum cutting depth of up to 38mm, most board thicknesses can be accommodated. Recommended for router table use only.www.axminstertools.com
If you can only buy your OSB in 8' sheets, how will you join the web? That, I think, is a more critical question, and less easily achievable in a DIY-environment.
I like the idea of a lamination to make up the length - much stronger than 2 lengths "butted" together with a finger joint.I can spend that, just in the clearance section.
That was my thought.
I have one of these - using it on the end of an 8ft piece of timber is going to be problematic - until I've built the bigger woodworkshop.
3-5 layers of 3mm ply laminated with staggered joints into a 16ft length was my first thought - impact adhesive will make a single composite sheet.
(I have lots of thin ply)
If I go with OSB, some beams I've seen in various videos appear to just have the webs butt joined. Possibly t&g, finger jointed, or half lapped, I suppose.
Any of those could be done with a handheld router.
I even saw one video where it appeared the web had vertical 6x1 braces over the joint.
I think fi could just fish the web with relatively short pieces of the same osb glued & covering either side of the butted Web.
Also I use the foaming polyurethane adhesives for engineering components & many many clamps
Where are you, anywhere nr Oxford?That would be my first choice - but I don't think I have that many clamps.
PU foam and many many MANY screws.
But as you get older......an overhead crane, even a single trolley on a beam is great.Lol.
I've made welded trusses in the past - I used to make car ramps big enough to lift a van 2ft off the floor.
Those are basically big triangular trusses .
I can cut and glue a wooden beam and have it on the roof before I've cut the diags for a steel one
"Crane trolley" is something I've never needed in 40 years. A pallet truck and an A-frame engine hoist has been more than sufficient.
Shame, I was going to offer the loan of clamps. Good luck with the project, post a few pics as you go along.Leeds.
I love a folding wedgeyou can clamp up rather well just by using wood wedges
I think clamping two sheets of ply, 16ft X 1ft, together using wooden wedges, would be an interesting engineering puzzle.you can clamp up rather well just by using wood wedges
It's still there. I've tried to get rid of it a couple of times but the local-ish farm/industrial museum couldn't be arsed to come and get it. If I'd delivered it to them, they'd probably have taken it, but would then likely eventually have scrapped it.I like the old lineshaft left on the wall![]()
